 Captura de tela 2024-12-16 142937.png (47kb) downloaded 1 time(s).O programa não adicional áudio e não quer fechar.
Hello. At first check your windows version if it is windows 11 24H2. If yes,then check Vmix version and if you have 26.0.0.45 or older,check vmix updates. You need to update at Vmix 26.0.0.46 or Vmix 27 or if you still are in Vmix 25 there also exist an update for it. There no exist other way to make vmix 26.0.0.45 and back to work in windows 11 24H2 version
