Youtube "real-time buffer too full" and orange flashing Stream button
Joined: 1/13/2010(UTC) Posts: 5,370  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
We do not recommend changing Windows network settings, as this could mess up things even more. As this issue only effects a very small number of YouTube streamers and not any other streaming providers, a change on the computer side of things is unlikely to help. One test you can try is to ping a.rtmp.youtube.com from the command line: Quote:ping a.rtmp.youtube.com
Pinging a.rtmp.youtube.com [142.250.67.12] with 32 bytes of data: Reply from 142.250.67.12: bytes=32 time=17ms TTL=115 Reply from 142.250.67.12: bytes=32 time=16ms TTL=115 Reply from 142.250.67.12: bytes=32 time=16ms TTL=115 Reply from 142.250.67.12: bytes=32 time=16ms TTL=115
Ping statistics for 142.250.67.12: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 16ms, Maximum = 17ms, Average = 16ms One theory is it relates to specific servers in specific locations, as a.rtmp.youtube.com automatically routes to what it thinks is the nearest server using a process called "Anycast". If the ping times are quite high (>100ms) then it indicates YouTube is not picking the best server for your location.
Joined: 10/21/2022(UTC) Posts: 24   Location: ankara Thanks: 16 times Was thanked: 4 time(s) in 3 post(s)
Originally Posted by: admin  We do not recommend changing Windows network settings, as this could mess up things even more. As this issue only effects a very small number of YouTube streamers and not any other streaming providers, a change on the computer side of things is unlikely to help. One test you can try is to ping a.rtmp.youtube.com from the command line: Quote:ping a.rtmp.youtube.com
Ping statistics for 142.250.67.12: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 16ms, Maximum = 17ms, Average = 16ms One theory is it relates to specific servers in specific locations, as a.rtmp.youtube.com automatically routes to what it thinks is the nearest server using a process called "Anycast". If the ping times are quite high (>100ms) then it indicates YouTube is not picking the best server for your location. ping a.rtmp.youtube.com Pinging a.rtmp.youtube.com [216.58.214.140] with 32 bytes of data: Reply from 216.58.214.140: bytes=32 time=84ms TTL=56 Reply from 216.58.214.140: bytes=32 time=73ms TTL=56 Reply from 216.58.214.140: bytes=32 time=84ms TTL=56 Reply from 216.58.214.140: bytes=32 time=85ms TTL=56 Ping statistics for 216.58.214.140: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 73ms, Maximum = 85ms, Average = 81ms
We have been broadcasting 10 hockey games a day on the same network via Blackmagic Web Presenter for 9 days. But when I try to stream via Vmix, it doesn't take more than 2 minutes for me to go to yellow. I don't think the problem is with YouTube. I think the problem is related to Windows.
Joined: 10/1/2013(UTC) Posts: 196  Location: Bovalino (Italy) Thanks: 86 times Was thanked: 3 time(s) in 3 post(s)
I find myself in the same conditions. Network on 4G LTE modem, speed test with excellent performance, like 40 mega down 40 up. Until last week everything was ok, today I find myself doing a live broadcast and after a few minutes the vmix stream flashes. If I stop everything and restart, it starts fine then after a few minutes it flashes again. I had to lower it to 1.5 megs to finish the transmission. I also have win10.
Joined: 3/21/2022(UTC) Posts: 52  Thanks: 1 times Was thanked: 9 time(s) in 9 post(s)
Originally Posted by: nerdygirljoni  I'm getting so frustrated and losing money. Does anyone know how to debug if a windows update is causing "real time buffer full" error? I'm more on the creative end of things and not so much the technical stuff so I don't even know where to begin, or what to say to viewers /big cry shrug/ Hi, things are complex, so lets try to break it down: - You need a stable network connection. Fiber or copper DSL is best, WiFi is a no-go and mobile networks can be tricky.
- Make sure you stream with constant bitrate (CBR) activated. If you don't, traffic shaping in the providers backbone can do all strange things. Cutting video from Powerpoint still slide to a moving crowd will most certainly create a hiccup in the upstream. Bitrate will rise, traffic shaping does not keep up and vMix can not transmit its video buffeers, you get the dreaded orange flashing.
- RTMP is no good, even if YT and lots of others support only this. RTMP is 20 years old, runs on TCP and is brittle in mobile networks, unstable networks and across continents. It gets worse with higher bitrates as well. The reaseons are complex, but unfortunately the problem is there. (Read this for details.
- In short: Use RTMP only up to 6-8 Mbit/s, use it on the same continent, use it on stable networks. Do intensive tests.
- On mobile networks, use SRT to get into the "real" Internet. You can set up a instance of DataRhei Restreamer on a VPS and go from there via RTMP to YT or other ingest points.
- Bandwidth tests are not enough. They help to set your bitrate - do not use more than 75% of what the speed test gives you. The other killer are jitter and packet loss. Try this website with Chrome/Edge and the proper parameters to get an idea how good your uplink is.
- If you stream to a Wowza server, make sure all the buffer parameters for ingest are set up correctly.
On mobile networks: - Use 5G if you can.
- Measure the available bandwith and adapt your upstream bandwidth accordingly.
- Use HEVC instead of H.264, if possible. Same quality, less bandwidth.
- Use SRT. Use SRT. Use SRT. :-)
- If you use bonding technology, understand how it works and do extensive tests. Use SRT.
Sorry that this is not easier, but hopefully these points may help you a bit. Good luck and let us know how is goes. Christian
 1 user thanked ckvideo for this useful post.
Originally Posted by: bulent_atlas  Pinging a.rtmp.youtube.com [216.58.214.140] with 32 bytes of data: Reply from 216.58.214.140: bytes=32 time=84ms TTL=56 Reply from 216.58.214.140: bytes=32 time=73ms TTL=56 Reply from 216.58.214.140: bytes=32 time=84ms TTL=56 Reply from 216.58.214.140: bytes=32 time=85ms TTL=56
This is interesting as it indicates Google is doing anycast via DNS instead of by IP. (The IP here is different to what we see in our tests from Australia for example) You can try setting your DNS servers in Windows to the Google DNS as per the following, then reboot and see if the ping has better results: https://developers.googl...ed/public-dns/docs/using
Joined: 10/30/2023(UTC) Posts: 39  Location: Hull Thanks: 3 times Was thanked: 6 time(s) in 6 post(s)
This problem seems to be getting worse. This week I was unable to get a good connection on any of the youtube ingest servers despite going round a / b / x / y several times.
I tried different CBR settings but it makes no difference. My video machine doesn't have the hardware to do HEVC unfortunately. We are only streaming at 3.5Mbps and have a tested upload speed of 20Mbps. If I go back through the recording it looks like Youtube is accepting one in every 2 or 3 frames. So apparently they are receiving at about 1.5Mbps
Thanks to all the VMix users and admins for their responses as it's almost certainly not a VMix problem but all advice is useful.
Another Sunday, another difficult streaming day. This week I tried a different approach. I set VMix to stream to both a.rtmp.youtube.com and b.rtmp.youtube.com (using the backup URL from the Youtube livestream page). Both streams going over the same 4G network connection. Today Speedtest was showing me 65mbps down and 20mbps up speed.
Initially the stream ran OK with both stream 1 and 2 showing Red (OK) on Vmix.
At 10.32 (GMT), stream 2 (b.rtmp) started flashing orange but stream 1 (a.rtmp) stayed on solid red. The youtube live control page started giving me warnings:
Warning: Please configure both primary and back-up streams correctly. The comparison of the streams failed because one of the streams has an invalid configuration. Warning: In the current configuration, the video's primary and back-up streams have different frame rates. You need to configure the streams to have the same frame rate.
This is a bit strange as both streams were being fed the same data by VMix, but I assume youtube is looking at the actual frames it is receiving rather than the settings of the stream. According to the vmix log it was dropping roughly 50% of frames on the b.rtmp stream.
So the big question is still, what is causing these frames to be dropped? I can't think it's anything at my end since the a.rtmp stream was getting through OK (and in fact both of them were for a while). The actual youtube livestream looks fine as I presume they used the a.rtmp stream which was not having problems.
Just for interest these are my ping results (using Google DNS 8.8.8.8 and 8.8.4.4):
Pinging a.rtmp.youtube.com [216.58.212.204] with 32 bytes of data: Reply from 216.58.212.204: bytes=32 time=57ms TTL=114 Reply from 216.58.212.204: bytes=32 time=58ms TTL=114 Reply from 216.58.212.204: bytes=32 time=67ms TTL=114 Reply from 216.58.212.204: bytes=32 time=57ms TTL=114
Ping statistics for 216.58.212.204: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 57ms, Maximum = 67ms, Average = 59ms
Pinging b.rtmp.youtube.com [64.233.184.134] with 32 bytes of data: Reply from 64.233.184.134: bytes=32 time=62ms TTL=114 Reply from 64.233.184.134: bytes=32 time=64ms TTL=114 Reply from 64.233.184.134: bytes=32 time=79ms TTL=114 Reply from 64.233.184.134: bytes=32 time=65ms TTL=114
Ping statistics for 64.233.184.134: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 62ms, Maximum = 79ms, Average = 67ms
Please keep this thread specifically about YouTube. Your logs look like the classic internet issues either on your ISP end or on the streaming provider's end and aren't related to the YouTube issues discussed here. See below: https://www.vmix.com/kno...mes-show-orange-or-amber
Originally Posted by: congoblue  Another Sunday, another difficult streaming day. This week I tried a different approach. I set VMix to stream to both a.rtmp.youtube.com and b.rtmp.youtube.com (using the backup URL from the Youtube livestream page). Both streams going over the same 4G network connection. Today Speedtest was showing me 65mbps down and 20mbps up speed.
Ping statistics for 64.233.184.134: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 62ms, Maximum = 79ms, Average = 67ms @congoblue, sorry things went wrong. Your problem is likely the 4G connection. At least here in Germany I made the experience that 4G networks have latency spikes up to 2000 ms every 40 seconds or so. This will kill the RTMP protocol and things will go orange on vMix RTMP streaming. Running two streams over the same RTMP mobile connection makes things worse, since the double amount of bandwidth is needed on the upstream to the mobile tower. In short: Do not use RTMP over mobile networks, if you can help it. If you can't help ist, get a mobile bonding solution and hope for the best. The better way ist to have a SRT->RTMP gateway somewhere in a datacenter on a VPS (Virtual private server). Than built your ingest stream like this: vMix -> SRT -> Mobile Network -> "Big Internet" -> SRT IN Gateway / RTMP OUT Gateway -> "Big Internet" -> YouTube Ingest THe gateway can be ffmpeg doing the translation or some Docker container doing it for you. My favourite is currently Datarhei Restreamer. If handling this is not for you, ask an IT friend to do it for you. Some more options: - restream.io seems to offer SRT ingest on their premium plans. I just read it, have no personal experience.
- Run OBS somewhere and ingest your SRT source there. Send the output stream to YouTube as RTMP. Make sure the connection from OBS to YouTube is stable and no mobile/WiFi.
- Try Multistreamer, this is the universal stream converter tool (commercial software). Here also make sure the RTMP connection to YouTube travels on a solid connection.
Tip: If you would check the quality of your connection, try the packet loss tester website at https://packetlosstest.com/. Pick the proper settings (Chrome only) and see what you get in terms of late packets and packet loss. Good luck and let us know how you move on. Best, Christian
Thanks Christian. The weird thing is this has operated fine using the same 4G equipment for over 2 years. But I guess there could have been some changes in the network recently. Unfortunately we are renting a school building and we are not allowed to connect to their fibre internet so mobile is the only option.
I realise running 2 streams is worse for the local connection, but as many others are reporting similar issues with Youtube I still think that it is possible the problem is at Youtube's servers, so as a test I was wondering if sending a backup might help. The difficulty is that this problem only shows up on a Sunday morning when we have started our church service so there is little freedom to test at this point. I cannot reproduce the problem at any other time (using the identical hardware setup, but at my house about 1km away so maybe a different cell tower).
Maybe Youtube will get a move on and implement their SRT ingest which they have been beta testing.
I am also going to try updating my VMix machine to Windows 11 as Windows 10 seems to be a common factor for this problem.
Hi, this is not cool. No way to get the school admin to patch you an "Internet only" link at your venue? About the 4G towers you are right, probably experiencing changes in the mobile network. Also, mobile cells tend to "breathe", so maybe somewhere around your tower someboy eles is streaming at the same time and you are now sharing cell tower bandwidth. Please do a packet loss test (https://packetlosstest.com/) and see what you get. During the stream, you can also ping a.rtmp.youtube.com and see if you get packet loss and/or changing roundtrip times. Since YouTube uses RTMP through their higly dynamic system, packet loss and jitter on mobile links can make things even worse. I agree, SRT ingest at YT for all yould be great, until than you need to use a cloud gateway SRT->RTMP. From which country are you? About vMix on Windows 11: I am wondering what is the root cause, I doubt the issue lies with Windows 10 in general. Did you check if you have the up to date network drivers on your system? This is just a wild guess, but since we are talking network issues here, a check would not do any harm... Best, Christian Originally Posted by: congoblue  Thanks Christian. The weird thing is this has operated fine using the same 4G equipment for over 2 years. But I guess there could have been some changes in the network recently. Unfortunately we are renting a school building and we are not allowed to connect to their fibre internet so mobile is the only option.
I'm in UK. I understand what you are suggesting with the VPS gateway but I am trying to avoid making it more complicated than it already is. The network situation at the school is complicated as they have a content moderation service which they cannot bypass and connecting through it is hard. I'll do some packet loss tests and ping tests during this Sunday's stream. I doubt it's Windows 10/ Windows 11 either but I can test it. The network drivers are all up to date for W10.
Originally Posted by: congoblue  I'm in UK. I understand what you are suggesting with the VPS gateway but I am trying to avoid making it more complicated than it already is. The network situation at the school is complicated as they have a content moderation service which they cannot bypass and connecting through it is hard. I'll do some packet loss tests and ping tests during this Sunday's stream. I doubt it's Windows 10/ Windows 11 either but I can test it. The network drivers are all up to date for W10. Hi congoblue, good luck, I'll be curious about the results, please let us know. From what you describe, you need to stick to mobile networks, which in turn means either using SRT, or use some sort of mobile bonding or risk a choppy RTMP transmission. If you do not want the VPS solution, you might use OBS somewhere else with stable network, stream there using SRT and go from there with RTMP to Youtube. You could combine this with the IRL OBS Switcher which changes scenes on ingest signal loss (have not tested it, though). If you need an SRT relay for testing, please PM me. Best, Christian
Hi Christian, I appreciate the offer of help, thank you. I upgraded our streaming laptop to Windows 11 this week and the stream was perfect, no problems at all. But it may just have been luck, I need to test for a few more weeks before I can tell if that has changed the behaviour. The youtube ingest servers resolved to completely different address ranges to the ones I got last week which may also be significant, it's possible Youtube has changed something at their end.
I ran packet loss tests while the stream was active (we again sent a main and backup stream over the 4G this week) and got 0 packets lost. Average latency: 130.7ms. Average jitter: 3.67ms
Ping results were similar to last week, a.rtmp.youtube.com resolved to 142.250.186.76, 73ms average ping. b.rtmp.youtube.com resolved to 172.217.168.12, 70ms average ping.
I am experiencing the exact same issue. I have vMix properly configured with a bitrate of 10,000 for 1080p. However, YouTube keeps reporting that the minimum required bitrate is not being met.
My internet connection is fiber, with a symmetrical speed of 500 Mbps for both download and upload. I tested this in a setup with multiple fiber internet connections, all of them offering excellent speeds, yet I consistently encountered the same YouTube error about low bitrate.
I even replaced my router, but the issue persisted. I also tested using a 5G router, and the problem remained, which clearly indicates that the issue is not related to the internet connection itself.
I tried streaming to other platforms, and it worked perfectly. I also tested streaming to YouTube using OBS, and it worked flawlessly. This leads me to believe that the problem is 100% related to vMix. I reached out to their support team, but they were unable to provide a resolution. Instead, they suggested that I should use OBS since I wasn’t having success with vMix, which I find unacceptable. After all, I purchased a vMix 4K license and expect to use it without needing to rely on OBS, which I personally do not like using.
Originally Posted by: PedroAkaLitos  I am experiencing the exact same issue. I have vMix properly configured with a bitrate of 10,000 for 1080p. However, YouTube keeps reporting that the minimum required bitrate is not being met.
Hi, I am not sure this is the same problem as I am having - for me, it works correctly initially, then after some minutes of streaming correctly, the stream button starts to flash orange on VMix and the VMix log reports "Real time buffer too full". Is that the same as what you are seeing? Have you tried using alternative youtube ingest servers (b.rtmp.youtube.com or x.rtmp.youtube.com)? What operating system is on your computer?
What I tried Alternative servers , my own rtmp server, backup server via obs, usb ethernet card, h264, HEVC, AV1, low bitrate, internet via mobile phone, google dns. None of them worked. I sent the broadcast for 10 days via the webpresenter on the same network. but I always got the same problem via the pc.
Originally Posted by: congoblue  Hi Christian, I appreciate the offer of help, thank you. I upgraded our streaming laptop to Windows 11 this week and the stream was perfect, no problems at all. But it may just have been luck, I need to test for a few more weeks before I can tell if that has changed the behaviour. The youtube ingest servers resolved to completely different address ranges to the ones I got last week which may also be significant, it's possible Youtube has changed something at their end.
Ping results were similar to last week, a.rtmp.youtube.com resolved to 142.250.186.76, 73ms average ping. b.rtmp.youtube.com resolved to 172.217.168.12, 70ms average ping. Hi congoblue, this all looks pretty normal. Looks like you ware lucky with 4G this time. :-) Did you make sure you are streaming with constant bit rate (CBR)? If not, than all weird things might happen randomly because of traffic shaping taking place in the transmission path. Best, Christian
