Recording Screen Capture on OBS - no audio!
I work in radio, and lately we’ve been using a LAWO mixer with vMix.
The issue I’m currently facing is trying to get audio from a Mac into the vMix, so that I can record it along with the video. I often don’t have the luxury of someone mixing it live, so having the chance to MultiCord me and a remote guest is gold.
However, the audio coming from the Mac (which I can hear through the LAWO) is not being recorded. The video is fine, but no audio is getting recorded. The Mac has OBS installed and we’re mostly using FaceTime and Teams to do remote video calls. I’m not super techy, but I can see that the input is configured as an SDI source.
Just reply me with whatever screenshots of settings you might need to assist me.
And just to clarify -the audio and video is coming through perfectly through the mixer itself. It’s just that I can’t seem to get the audio from it recorded in vMix. It doesn’t give off any green bars when sound is noticed like the other mics.
Joined: 12/24/2021(UTC) Posts: 733  Location: athens Thanks: 166 times Was thanked: 96 time(s) in 92 post(s)
Hello. So to understand your setup. Your Mac has OBS and an sdi capture card from which have an sdi cable that goes inside vmix? Is it a decklink card and from OBS you go to decklink output and you send it out? How it goes inside vmix pc? What is your input capture card in Vmix? Also you mention "And just to clarify -the audio and video is coming through perfectly through the mixer itself. It’s just that I can’t seem to get the audio from it recorded in vMix. It doesn’t give off any green bars when sound is noticed like the other mics." I did a quick google search and i see that this LAWO mixer is audio mixer. Is there exist also a video/audio switcher from this brand? If not,how do you get in the audio mixer,the video?
