Instant Replay
Replay Input within bundle problem
Joined: 12/27/2012(UTC) Posts: 5,541  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
As the title says:
Transfering a bundle that includes a Instant Replay input to another pc (no recordings within) , while the asset window to load individual items shows both replay inputs present checked, once loaded there is only one input for it shown but not as a replay one . Hitting the change it does become the IR setup page. confirming it indeed changes it to a Replay input be it the A one, but there is no B one to be seen
Not sure if it has to do with transfering between v27 (windows 10) and v28 (windows 11) Maybe even related to the fact that one can not change the session folder once a IR has been added (have to delete and add one again in order to change session folder possibility first. Other inputs that one changes tell you that the current one has to close/shut down first but IR doesnt give that option). Ability to change a session folder within the IR input allows one to open previous sessions for review again instead of having to delete All and loosing the footage
Joined: 1/13/2010(UTC) Posts: 5,375  Location: Gold Coast, Australia Was thanked: 4801 time(s) in 1648 post(s)
So, this is not related to 28 or bundles, but due to the fact that at the time of loading the preset the replay folder does not exist. When this happens for normal inputs, they will be offline until changed or reset, but due to Replay needing two inputs this does not work properly.
For now, the fix is to make sure the replay folder exists in the same location. It is not really advised to move replays between machines, and we will probably need to note this in the documentation.
Originally Posted by: admin  So, this is not related to 28 or bundles, but due to the fact that at the time of loading the preset the replay folder does not exist. When this happens for normal inputs, they will be offline until changed or reset, but due to Replay needing two inputs this does not work properly.
Ok, thank you Have a small workaround though Intended for transfering a setup with various replay inner settings (tags,eventnames etc) included without recorded footage! Provide the bundle AND a copy of the replay folder Open the bundle, the replay input will show as offline Go into configuration of the replay input and select change , will automatically show the IR GUI setup select the location (point to) of the copied (provided) replay folder and hit ok save the bundle or as new preset and open either one of them Setup complete Beat having to explain detailed IR setup settings and includes all specific shorcuts/scripts (marked as for this preset only) for this setup to a remote PC PS my presets include cam inputs (as images to be changed) so the scripts and shortcuts match the location of those etc
Instant Replay
