vMix silent install via Powershell
Is it possible to install vMix silently via Powershell?
e.g. something like that
$installFile = "vmix23.exe" Start-Process $installFile -ArgumentList "--silent" -Wait -NoNewWindow
Have you find the way to do it? I need to do exactly the same
Because I need to install vmix by using powershell, with no user-interaction
Commonly that's achieved by the proper non-interactive/silent flag
No, I did not figure it out yet. I am not a Windows person, so having been trying different Powershell options. My goals is to pre-bake AWS AMIs with Vmix pre-installed via Packer
Originally Posted by: vitbyst  No, I did not figure it out yet. I am not a Windows person, so having been trying different Powershell options. My goals is to pre-bake AWS AMIs with Vmix pre-installed via Packer
So ignore my previous answer. This works: Start-Process -FilePath $installer -ArgumentList "/VERYSILENT" -Wait
yes, I think it worked. Testing it now. e.g.
########################## variables ########################################### $region = "us-east-1" $bucket = "s3://my-packer-s3-bucket-fakename" $downloadFolder = "vmix" $tempFolder = "C:\cfn\downloads" $region = "us-east-1" $installFile = "vmix23.exe" ################ function Get-TimeStamp {
return "[{0:MM/dd/yy} {0:HH:mm:ss}]" -f (Get-Date)
} ########################## download package ####################################
if (!(test-Path -Path $tempFolder)) {mkdir $tempFolder} aws s3 sync $bucket/$downloadFolder $tempFolder\$downloadFolder Write-Output "$(Get-TimeStamp) $installFile has been downloaded into $tempFolder\$downloadFolder" ########################## install package ###################################### Start-Process $tempFolder\$downloadFolder\$installFile -ArgumentList "/VERYSILENT" -Wait -NoNewWindow Write-Output "$(Get-TimeStamp) $installFile has been installed"
I know it’s been years has anyone had any luck recently with vmix 27? I seem to get snagged during install and haven’t been able to get it to complete.
Even better if I can embed a license into the scripting
