Dist
#1 Posted : Thursday, December 5, 2024 7:30:09 AM(UTC)
Dist
Was thanked: 26 time(s) in 18 post(s)
The latest vMix beta, 28.0.0.24 includes "Optimised API XML to reduce latency spikes in extreme situations (thousands of requests per minute)", can it please also be documented that you've changed the schema as the XML (both by the HTTP endpoint and through TCP) prepend "<?xml version="1.0" encoding="utf-16"?>".
This can be a breaking change for 3rd parties, as it's a change to the XML structure that is not mentioned and even the help documentation still has examples starting with <vmix>, not <?xml version="1.0" encoding="utf-16"?><vmix>
I'm still checking to see if anything else is changed beyond this, as there's no information in the change log to go on, so if there are more changes then please document them all.
nikosman88
#2 Posted : Thursday, December 5, 2024 7:57:31 AM(UTC)
nikosman88
Greece
Was thanked: 91 time(s) in 87 post(s)
Hi Dist. Thank you very much for your great work in Vmix companion module! What you say about the XML may be the reason that i cannot run vmix utc at latest beta vmix 28.0.24? At first i thought that it cannot run at vmix 28 at all,but after try and test, i see that in Vmix 28.0.0.22 runs ok but on vmix 28.0.0.24 cannot sync
And also if we try something like this video says
it says a message Error:"There is no Unicode byte order mark.Cannot switch to unicode" While until version 0.22 work ok
#3 Posted : Thursday, December 5, 2024 12:40:35 PM(UTC)
Was thanked: 4485 time(s) in 1564 post(s)
Thanks for reporting this, it has now been fixed in 28.0.0.25
raugert on 12/6/2024(UTC)
