66 Pages«<6263646566>
kevev
#1261 Posted : Saturday, February 17, 2024 12:45:57 PM(UTC)
kevev
Was thanked: 9 time(s) in 5 post(s)
Is there a way to make buttons that show/hide image State Dependent using SetXVisible? I would like for the status LED to show RED when image is visible. Thank You. :)
Luis70
#1262 Posted : Saturday, February 17, 2024 1:33:31 PM(UTC)
Luis70
Grenada
Was thanked: 8 time(s) in 8 post(s)
I asked this question years ago with no answer....I now use vMix Panel Builder...I can create my own buttons and lay them out to mimmick an hardware switcher...similar to the Blackmagic software switcher...
kevev
#1263 Posted : Saturday, February 17, 2024 3:57:17 PM(UTC)
kevev
I am hoping elgarf has an option.
Luis70
#1264 Posted : Saturday, February 17, 2024 8:18:16 PM(UTC)
Luis70
Grenada
The UTC switcher is great, just that it has no real UI.....I only wish that it hhad one,...but like I said...I am using Panel Builder, and that works great... got some ideas, and a few templates off this site from a guy called Bardos some years ago, and I developped my own....with labeled buttons, a T-Bar, the full works....
howardsd
#1265 Posted : Monday, May 27, 2024 8:29:57 PM(UTC)
howardsd
Upon trying to re-open a Scoreboard controller I was working on, I was not allowed to open it. I got an error message while trying to load the saved file.
mattmigz
#1266 Posted : Monday, July 22, 2024 6:45:37 PM(UTC)
mattmigz
Hi all,
Excited to try the UTC Title Controller out, but the app keeps crashing when I open it. I'm receiving this error log in Event Viewer:
Anwendung: vMixController.exe
Frameworkversion: v4.0.30319
Beschreibung: Der Prozess wurde aufgrund einer unbehandelten Ausnahme beendet.
Ausnahmeinformationen: System.ArgumentOutOfRangeException
bei System.String.Substring(Int32, Int32)
bei NewTek.NDI.Source.set_Name(System.String)
bei NewTek.NDI.Source..ctor(source_t)
bei NewTek.NDI.Finder.FindThreadProc()
bei System.Threading.ThreadHelper.ThreadStart_Context(System.Object)
bei System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
bei System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
bei System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
bei System.Threading.ThreadHelper.ThreadStart()
Can anyone help me decipher this and resolve the issue?
Thank you in advance :)
-Matt Migz
NSCPro
#1267 Posted : Thursday, August 8, 2024 9:46:24 AM(UTC)
NSCPro
Estonia
I think that no one is working on fixing these errors anymore, because for some reason there is a feeling that it is no longer supported or developed anymore.. because the last version is already almost 1.5 years old
Luis70
#1268 Posted : Thursday, August 8, 2024 12:53:09 PM(UTC)
Luis70
Grenada
Try vMix Panel Builder ... works great, has the ability for you to personalize how it looks....
NSCPro
#1269 Posted : Friday, August 16, 2024 4:59:22 AM(UTC)
NSCPro
Estonia
Why builder? This not support many many an important opportunity?
When UTC ok? when will the new version come out?
I can pay these brothers even if they want, it's not a problem, just tell me the amount and let me sort out my affairs
NSCPro
#1270 Posted : Saturday, August 17, 2024 12:24:29 AM(UTC)
NSCPro
Estonia
in order for UTC to work normally or well, what programs must be installed in Windows?
nikosman88
#1271 Posted : Saturday, August 17, 2024 4:31:58 AM(UTC)
nikosman88
Greece
Hi. I use windows 10 without any extra software for UTC to work. I simply run the exe and it runs. But i see many days your posts about your problem. You are willing to pay for anyone to upgrade this software. Well the good thing is that the developer of this software has the source code for free https://github.com/elgarf/vMixUTC
So if you know programming or if you are willing to pay anyone who knows he can take this code and fit to your needs or even find why is not running in your system. Even if you know little from programming may you can use an AI program to code for you. Personally i did it with another vmix 3rd party program some little changes in the source code without any actual knowledge of coding
Also something else in the first post the last version from 7-11-2022 but in the github https://github.com/elgarf/vMixUTC/releases it is from 26/3/2023. ok quite old also but if you didnt try, you can try if this newer version works for you
thanks 1 user thanked nikosman88 for this useful post.
Chircanu on 8/17/2024(UTC)
NSCPro
#1272 Posted : Saturday, August 24, 2024 9:51:27 AM(UTC)
NSCPro
Estonia
I allready use latest version. I can’t update NDI dll file or other dll files. NDI not working, every time is crashed and if I look Event Viewer Log i see NDI error.
RyanMoraes
#1273 Posted : Monday, October 7, 2024 7:05:05 AM(UTC)
RyanMoraes
Brazil
Hello Guys,
I'm having some problems with my UTC and the first step was that I was having some problems with the NDI Monitor, so what some friends told me that I should disable the .dll file for NDI and the UTC would work fine. I did that and I was able to open the UTC but I couldn't even open those projects that had NDI Monitors even with the problem with the .dll file. So I had to remake all the projects that had this issue but the point is that I was using my personal computer to make adjustments on UTC and I was using my cellphone network and when I switched to the company's Wi-Fi, the UTC closed unexpectedly and showed me this error which is in portuguese:
System.InvalidOperationException: Erro no documento XML (2, 182690). ---&gt; System.Xml.XmlException: Fim de arquivo inesperado. Os seguintes elementos não estão fechados: DataProviderContent, vMixControl, ArrayOfVMixControl, Controls, Root. Linha 2, posição 182690.
em System.Xml.XmlTextReaderImpl.Throw(Exception e)
em System.Xml.XmlTextReaderImpl.Throw(String res, String arg)
em System.Xml.XmlTextReaderImpl.ThrowUnclosedElements()
em System.Xml.XmlTextReaderImpl.ParseElementContent()
em System.Xml.XmlTextReaderImpl.Read()
em System.Xml.XmlReader.ReadString()
em System.Xml.XmlTextReaderImpl.ReadString()
em System.Xml.XmlReader.ReadElementString()
em Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read23_vMixControlExternalData(Boolean isNullable, Boolean checkType)
em Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read40_vMixControl(Boolean isNullable, Boolean checkType)
em Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read41_ArrayOfVMixControl()
--- Fim do rastreamento de pilha de exceções internas ---
em System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events)
em System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader)
em vMixController.Classes.Utils.LoadController(Stream stream, IList`1 functions, MainWindowSettings&amp; windowSettings)
em vMixController.Classes.Utils.LoadController(String fileName, IList`1 functions, MainWindowSettings&amp; windowSettings)
P.S. Don't be afraid, your controller is OK.
Report about it on forum.
Please, can someone help me out with this problem? Is like 2 problems in 1 message but what I think is that the problem is the network, but the engineers said that it was all ok.
Thanks by the way
howardsd
#1274 Posted : Monday, October 28, 2024 7:04:52 AM(UTC)
howardsd
System.InvalidOperationException: There is an error in XML document (1, 184296). ---&gt; System.Xml.XmlException: Unexpected end of file has occurred. The following elements are not closed: A, PairOfStringString, Paths, vMixControl, ArrayOfVMixControl, Controls, Root. Line 1, position 184296.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.Throw(String res, String arg)
at System.Xml.XmlTextReaderImpl.ThrowUnclosedElements()
at System.Xml.XmlTextReaderImpl.ParseElementContent()
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.XmlReader.ReadString()
at System.Xml.XmlTextReaderImpl.ReadString()
at System.Xml.XmlReader.ReadElementString()
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read11_PairOfStringString(Boolean isNullable, Boolean checkType)
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read21_vMixControlList(Boolean isNullable, Boolean checkType)
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read40_vMixControl(Boolean isNullable, Boolean checkType)
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read41_ArrayOfVMixControl()
--- End of inner exception stack trace ---
at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events)
at vMixController.Classes.Utils.LoadController(Stream stream, IList`1 functions, MainWindowSettings&amp; windowSettings)
at vMixController.Classes.Utils.LoadController(String fileName, IList`1 functions, MainWindowSettings&amp; windowSettings)
Pothala
#1275 Posted : Thursday, December 5, 2024 3:12:28 AM(UTC)
Pothala
Spain
I need help with the following problem, in a Vmix entry 3 called Multiwindow I have on a video source a layer at index 1 which is a window with the content of entry 1 (This entry is called Red), in entry 2 I have different content (this entry is called green). With UTC I want a drop-down list to read all the entries in the project and the one I select is composed of the Multiview entry in layer 1.
I have managed to create an XML Data called INPUTS (url: http://127.0.0.1:8088/API; xpath: /vmix/inputs/input) that lists the names of all Vmix inputs.
I have created a drop-down list associated with the INPUTS Database, that when I click the drop-down list, all the names of the inputs are shown, and I can select any of them.
What I need is for the entry name selected in said list to be displayed in the entry called Multiview in layer 1.
I don't know if I have explained myself well.
Basically I want to do with UTC with a drop-down list, an array to select the signal that I want to appear in a multiview window.
Thanks in advance.
nikosman88
#1276 Posted : Thursday, December 5, 2024 6:43:17 AM(UTC)
nikosman88
Greece
Thanks in advance.
Other than this i tried on utc and what you mean as the drop list is the "show rows" button that opens a list or the other list? If so,im 90% sure that both these lists is only for reference and for title mapping but for select a input and switch to it,this way is beyond this.T If this is true you need to make buttons or shortcuts or script that will send any of your inputs in the layer you need. May helps you the vmix video about dynamic inputs in layers. There are other ways to do what you need more easy.
elvis55 on 12/12/2024(UTC)
ojtecnico@gmail.com
#1277 Posted : Wednesday, December 11, 2024 8:29:34 PM(UTC)
ojtecnico@gmail.com
Spain
Thanks in advance.
I am interested in this matter too. I understand that what you want is that with a drop-down list, in which the project entries are shown, when selecting a certain entry, a certain action can be associated with it, such as sending that entry selected in the list to a certain output.
VictorV
#1278 Posted : Wednesday, January 29, 2025 1:43:05 PM(UTC)
VictorV
Canada
System.InvalidOperationException: There is an error in XML document (1, 602045). ---&gt; System.Xml.XmlException: Unexpected end of file while parsing Name has occurred. Line 1, position 602045.
at System.Xml.XmlTextReaderImpl.ParseQName(Boolean isQName, Int32 startOffset, Int32&amp; colonPos)
at System.Xml.XmlTextReaderImpl.ThrowTagMismatch(NodeData startTag)
at System.Xml.XmlTextReaderImpl.ParseEndElement()
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read8_Color(Boolean checkType)
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read12_vMixControlTextField(Boolean isNullable, Boolean checkType)
cody@raceontexas.com
#1279 Posted : Thursday, February 13, 2025 6:53:00 AM(UTC)
Does this program just crash for everyone else? I save it crashes, I try to edit something it crashes. I have lost more work because of this and its starting to get annoying.
CanaldoCria
#1280 Posted : Friday, March 21, 2025 10:57:19 PM(UTC)
CanaldoCria
Brazil
bom dia
estou tendo problem,as em executar o UTC
procurei nos eventos do windows e ele me deu esse diagnóstico
Falha no preparo de metadados; resultado=0x80070490 para o contêiner '{98F60411-D9B0-11EF-8560-10FFE022E96C}'
como resolver?
Guest (22), LazLong
