Feature Requests
Multicast for "SDI must DIE"
Hello! I want move from SDI to IP-based video workflow and replace traditional video mixers to vMix, please, add Milticast (RTP and UDP) as Input (first), as Output (next) with many codecs and formats. Multicast is amazing! Multicast is easy and cost effective for video solution! I can easy view and record Multicast (VLC, ffmpeg, mplayer) on every PC with ethernet, without CPU utilisation for distribution (every new stream)! Please read presentation: "SDI must DIE" (page 57) http://pbs.bento.storage...eo%20over%20IP_FINAL.pdfPlease add to vMix: 1) Multicast as Input and Output (RTP and UDP, range 239.0.0.0 to 239.255.255.255 (http://tools.ietf.org/html/rfc2365))! 2) Maybe add library from ffmpeg project for many codecs and formats (avcodec-56.dll, avformat-56.dll etc)? 3) Improve compatibility growing files (write stream to file for time delay - as Input) Thank you!
there is a delay in IP casting so not usable for live video with audio syncing. SDI is great!
but for playout server stuff and maybe other locations input and switching to a single playout channel or so it is ofcource great to use ip.
I want use multicast feed from satellite headend now (DVBlast daemon). PLEASE add multicast stream as input (MPEG2 and H264)! Maybe via ffmpeg?
Thank you!
Feature Requests
