neato23
#1 Posted : Friday, November 29, 2024 5:24:57 AM(UTC)
neato23
Good afternoon everyone,
Just had a quick question or maybe problem. I grabbed the Contour ShuttlProV2 as we're looking at add replays to our shows and I'm having an odd problem. Truthfully, it might be me.
I've got some replays that we captured from a recent event loaded up and I'm just playing around trying to understand the controller.
when I Scrub the timeline with the wheel (Live is Off). I can select a clip in point with the controller, but once I start scrubbing again, it continues to change in clip in time instead of going to the clip out time. So ultimately I end up with a clip starting and stopping at the same time....
Maybe I'm doing something wrong here?
I'm using the template from vMix for the controller.
neato23
#2 Posted : Friday, November 29, 2024 5:39:19 AM(UTC)
neato23
Told you I was doing something wrong. I had Central Control going in the background with some different settings... All works well now.
