Beta Discussion
Outputs information added to API XML-SRT information and Outputs appear or not in the API
Joined: 12/24/2021(UTC) Posts: 500 Location: athens Thanks: 121 times Was thanked: 71 time(s) in 67 post(s)
Hello. I see in the API xml the outputs. When we have in a output the NDI ON it says <output type="output" number="1" source="Output" ndi="True"/> and if we close the ndi on this output and refresh the 127.0.0.1:8088/api immediatelly it changes to <output type="output" number="1" source="Output"/> For SRT the API says <output type="output" number="1" source="Output" srt="True"/> but even if we disable it or stop transmitting and then refresh the api page it continues to say <output type="output" number="1" source="Output" srt="True"/> and it doesnt change to inform us that we dont srt out from this output. If we close vmix and then open it and have srt outs disabled, it reads correctly that srt is not transmit. To me seems like this value somehow is not realtime informed Is this only me,by design or bug? Thanks for any answer
Also i think a bug with the outputs section in the API how they appear or not.Im attaching some photos from the vmix--->settings-->outputs/ndi/srt and please if you can do the combinations of the overlay channels like my photos (all on/off etc) asnd check the API what happens to the outputs info In my tests if for example i have disabled in the output 2 the 4 channel overlay,then the output 2 info is not appeared in the API and same for the output 3. If overlay channel 4 is not checked on,then the info for what output 3 is,not appear in the API out3.png (36kb) downloaded 0 time(s). out4.png (36kb) downloaded 0 time(s).thanks for any answer
Beta Discussion
