#1 Posted : 7 months ago
Was thanked: 4475 time(s) in 1560 post(s)
vMix 28 Preview (28.0.0.19 Beta) is here!
Disclaimer: This is a preview release for those who like to live on the edge! There will still be some bugs, so it should not be used in productions.
Your feedback is greatly appreciated, please report any bugs or issues in the Beta Discussion forum.
Updates: If you purchased vMix prior to 1 January 2023, an additional purchase is required to use this beta or a new Trial may be possible if you have only used the Trial once in the past. Finally, an edition upgrade (say from HD to 4K) will also include 12 months of free updates.
https://account.vmix.com/order/?Upgrade=1
Note: New features should not be submitted here, please use the Feature Requests forum instead.
Download Links
https://cdn.vmix.com/download/vmix28preview.exe
Zoom Plugin for vMix
https://www.vmix.com/zoomplugindownload
New Features and Changes
* NEW Web Telestrator/Monitor in Web Controller
Turn any modern browser into a Telestration device!
Supports iPad, iPhone, Android tablets and most devices and computers with the latest Safari, Chrome, FireFox or Edge browsers.
Includes a low latency video preview and up to 10 dedicated shortcut buttons for remote control.
* NEW System / Application Audio Inputs
Capture the audio from Windows, automatically excluding the audio in vMix.
Additionally, capture the audio from a single Windows application.
* NEW Playback Time Triggers
OnPlaybackTime and OnPlaybackRemaining triggers allow configuring actions a few seconds before a video completes, or
at multiple key moments throughout playback.
* NEW MultiView2 and MultiView enhancements
A second MultiView is now available with its own unique configuration.
MultiView outputs can now just show inputs, or only a single input to use as a confidence monitor.
MultiView sources can be configured to show Mix inputs directly.
MultiView audio meter can be changed from default Master.
* NEW Mix input support for Overlays and Stingers
Overlay and Stinger shortcuts can now be configured to display in one or more Mix inputs instead of or in addition to the Output.
Stingers can also be directly started for a Mix input from its built in transition button.
Mix inputs can now also be assigned directly to an Output.
* NEW GT Anchor setting
Control the animation direction and sizing of text objects with the new Anchor setting in GT.
Allows expansion of auto-width text elements from the right instead of the left for example.
* NEW Flatten Layers
Added Flatten Layers checkbox to each input. This combines all the layers together as a single "flat" input when used as a source in other inputs.
This is useful for cropping all layers at once for example.
* 5 Streaming Destinations
Streaming destinations increased from a maximum of 3 to 5.
* NDI 6
vMix now supports the latest NDI release. Note that vMix does not support HDR.
HDR NDI sources will still display, but may have incorrect colour and/or luminance due to SDR conversion.
* Audio
Right click menu to show all buses on an audio mixer as smaller buttons.
Audio Bus Manager will now update in realtime in response to shortcuts or mouse clicks in main mixer
Settings - Audio checkbox to disable scrollwheel adjusting audio faders
* New Shortcuts
VideoCallConnect, VideoCallReconnect, ZoomJoinMeeting
SetBusFolumeFade
SetStingerGTInput1-4
* Other updates
Production Clock now supports time remaining for video currently playing in Output
SRT updated to version 1.5.3
Support for high frame rates in Decklink cards
AJA support for Kona X
Web Browser input custom CSS support
New Encoder tab added to Statistics, provides an overview of all the encoders currently in use. Handy to determine how many NVENC are remaining on GeForce cards.
Added Recording Buffer option to Replay, to provide additional storage buffering to compensate for sustained performance issues on some SSDs
Outputs information added to API XML
Removed the following streaming destinations, due to being discontinued or no longer adequately supported: StreamSpot, TikiLIVE, Twitter
If you are using these streaming destinations, refer to the provider's documentation on using the RTMP streaming option in vMix instead.
Documentation
https://help.vmix.com/28/
thanks 30 users thanked admin for this useful post.
Chircanu on 11/7/2024(UTC), tsioukas on 11/7/2024(UTC), doggy on 11/7/2024(UTC), TenSob_ on 11/7/2024(UTC), richardgatarski on 11/7/2024(UTC), JakeyBoyPro on 11/7/2024(UTC), kuuminsh on 11/7/2024(UTC), nikosman88 on 11/7/2024(UTC), Priders on 11/8/2024(UTC), eduardocfs on 11/8/2024(UTC), ryxyz on 11/8/2024(UTC), thecloudmediagroup on 11/8/2024(UTC), Guycochran on 11/8/2024(UTC), Salvatore on 11/8/2024(UTC), ksinnott on 11/8/2024(UTC), jet on 11/8/2024(UTC), Vasiloiu99 on 11/9/2024(UTC), stevespaw on 11/9/2024(UTC), Jurgen on 11/9/2024(UTC), tridenator on 11/9/2024(UTC), monamiga on 11/9/2024(UTC), vijay6672 on 11/10/2024(UTC), ON.tv Channels on 11/12/2024(UTC), sinc747 on 11/13/2024(UTC), jsing on 11/14/2024(UTC), stigaard on 11/15/2024(UTC), QuiapoChurch on 11/25/2024(UTC), avsoundguy on 11/27/2024(UTC), chiscort on 12/2/2024(UTC), mlatta on 12/13/2024(UTC)
#2 Posted : 6 months ago
28.0.0.20 Preview Released
Use the same download link above or run vMix Update
* Browser CSS box is now hidden for older browser versions.
* Fix for Output settings not importing from older versions of vMix correctly.
* Fix for issue where SRT inputs may freeze when closing vMix
* Added toggle in Settings -> Audio Outputs to Always show all Bus buttons in Audio Mixer
thanks 14 users thanked admin for this useful post.
WaltG12 on 11/13/2024(UTC), jet on 11/13/2024(UTC), ryxyz on 11/13/2024(UTC), sinc747 on 11/14/2024(UTC), jsing on 11/14/2024(UTC), stigaard on 11/15/2024(UTC), nikosman88 on 11/20/2024(UTC), Chircanu on 11/22/2024(UTC), raugert on 11/23/2024(UTC), monamiga on 11/25/2024(UTC), avsoundguy on 11/27/2024(UTC), ZIKLAG MISSION on 12/4/2024(UTC), mlatta on 12/13/2024(UTC), eduardocfs on 1/20/2025(UTC)
#3 Posted : 6 months ago
28.0.0.22 Preview Released
Use the same download link above or run vMix Update if an earlier 28 is already installed.
* Early beta support for Bluesky added to vMix Social
* Upgraded SRT to latest 1.5.4 which has fixes for some scenarios that can cause everything to freeze up
* Improved SRT decoder resiliency to bad encoders
* Fixed new Outputs in XML API not showing up to date information
thanks 9 users thanked admin for this useful post.
jet on 11/26/2024(UTC), nikosman88 on 11/26/2024(UTC), raugert on 11/27/2024(UTC), avsoundguy on 11/27/2024(UTC), monamiga on 11/27/2024(UTC), BroadcastScot on 11/30/2024(UTC), mlatta on 12/13/2024(UTC), stigaard on 12/21/2024(UTC), eduardocfs on 1/20/2025(UTC)
#4 Posted : 6 months ago
28.0.0.24 Preview Released
* Fix for Decklink inputs missing on the latest 14.3 drivers
* Numbers added to vMix UI Preview/Output to match MultiView Output
* Optimised API XML to reduce latency spikes in extreme situations (thousands of requests per minute)
* Optimised Replay XML to reduce latency spikes in extreme situations (thousands of events)
* Fixed Stream 4 and 5 indicators missing
* Added support for selecting a different Mix to display in Preview/Output/Input highlight indicators in MultiView output
* Added SRT IPv6 support
* Added support for 3rd party HTTPS proxy connecting to Web Controller/Telestrator
* Telestrator Fullscreen button now hidden on iPhone as these devices do not support fullscreen at all
* Fixed statistics error when changing number of Replay cameras in use
thanks 10 users thanked admin for this useful post.
Unieveth on 12/3/2024(UTC), jet on 12/3/2024(UTC), ryxyz on 12/4/2024(UTC), chiscort on 12/4/2024(UTC), nikosman88 on 12/4/2024(UTC), monamiga on 12/4/2024(UTC), mlatta on 12/13/2024(UTC), stigaard on 12/21/2024(UTC), Aki on 1/3/2025(UTC), eduardocfs on 1/20/2025(UTC)
#5 Posted : 6 months ago
28.0.0.25 Preview Released
* Fixed Replay issue when opening replay input twice accidentally
* Fixed XML API output not matching previous versions
* Fixed Fullscreen dropdown menus not updating after turning on or off one of the displays in settings
thanks 7 users thanked admin for this useful post.
jet on 12/5/2024(UTC), monamiga on 12/5/2024(UTC), nikosman88 on 12/5/2024(UTC), raugert on 12/6/2024(UTC), mlatta on 12/13/2024(UTC), stigaard on 12/21/2024(UTC), eduardocfs on 1/20/2025(UTC)
#6 Posted : 5 months ago
28.0.0.27 Preview Released!
* Updated NDI to 6.1.1
* Windows Update disable feature updated to also now temporarily disable a second service Windows may use for updates.
* New shortcuts: ReplayJumpToSelectedInPoint, ReplayJumpToSelectedOutPoint, ReplaySetChannelAToBTimecodeAndCamera, ReplaySetChannelBToATimecodeAndCamera, ReplayUpdateSelectedSpeedFromValue
* New trigger: OnReplayEventsCompleted
* Telestrator image dialog will now show custom images first
* vMix will now show if the currently selected graphics card supports Resizable Bar with the "ReBAR" indicator in Settings -> Performance.
* If ReBAR is enabled, the GPU Mem % will no longer be limited to just the GPU cache memory.
* Fixed issue when changing or appending a Replay input in a preset
* Fixed vMix not closing if a List input was in between loading a video at the time.
* Fix for SRT MultiCorder dropping frames under heavy load
* Updated Border and Colour Key colour selection windows to the new dialog.
* Fix for PTZ, Mix and Virtual Set button and dropdown text too small on High DPI displays
thanks 8 users thanked admin for this useful post.
doggy on 1/6/2025(UTC), ryxyz on 1/6/2025(UTC), jet on 1/7/2025(UTC), monamiga on 1/7/2025(UTC), nikosman88 on 1/8/2025(UTC), QuiapoChurch on 1/10/2025(UTC), eduardocfs on 1/20/2025(UTC), stigaard on 1/21/2025(UTC)
#7 Posted : 4 months ago
28.0.0.31 Preview Released!
* Added ability to click Inputs in MultiView to send them to Preview. This also works in the Telestrator.
This requires turning on the checkbox in the Settings -> Outputs - MultiView - Customise Layout settings
* Added support for SVG images in Telestrator
* Mixes dropdown box in Shortcuts, Triggers etc improved with all on / off toggles
* Fixed log error when there are gaps in audio buses (A + C but not B for xample)
* Added support for Set/SwapLayerAnimated to allow multiple layer movements at the same time within a single input.
* Fixed issue with Telestrator undo, updates on multiple screens not always being in sync.
* General Telestrator improvements when under poor network conditions (such as bad WiFi)
* General Telestrator interface improvements
* Fix for SRT IPv6 not working in Rendezvous mode
jet on 1/13/2025(UTC), ryxyz on 1/14/2025(UTC), EscapingKid on 1/14/2025(UTC), monamiga on 1/14/2025(UTC), sinc747 on 1/14/2025(UTC), eduardocfs on 1/20/2025(UTC), stigaard on 1/21/2025(UTC)
#8 Posted : 4 months ago
28.0.0.33 Preview Released!
* Fix for vMix Call issue with Google Chrome 132
* Telestrator will now save and recall toolbar settings automatically in each browser
* Right click Telestrator Input now has link to open up Web Controller directly
jet on 1/19/2025(UTC), StepBackInTime_TV on 1/19/2025(UTC), sinc747 on 1/20/2025(UTC), monamiga on 1/20/2025(UTC), tridenator on 1/20/2025(UTC), eduardocfs on 1/20/2025(UTC), Chircanu on 1/21/2025(UTC), stigaard on 1/21/2025(UTC), SPSTech on 1/22/2025(UTC), mlatta on 1/23/2025(UTC)
#9 Posted : 4 months ago
vMix 28 has now been released out of beta!
Full details on the Download page:
https://www.vmix.com/software/download.aspx
robertskiba on 1/28/2025(UTC), monamiga on 1/29/2025(UTC)
