Swap input but keep layers assignments
Is there a way to swap an input with another one, but have that new input assigned on all the other inputs the original input was a layer of?
Context, we have a bunch of inputs (30+) with different layers and they all have an audio input as layer 1.
We have another input that is a zoom input, with some settings.
Is there a way to easily replace the audio input with the zoom input, have that zoom input assigned as layer 1 on all these other inputs where the audio input was?
For context, I know about the "change" option on the audio input. The issue, specifically with Zoom when using change, is it has to be resetup from scratch. We have the zoom input set a certain way: Participant source type video, Audio source mixed, meeting settings original sound, etc. When using change, we have to manually reselect all our zoom settings.
So looking for a way to swap Input A with Input B, but have it transfer all the assignments from Input A.
Thank you!
Joined: 7/4/2021(UTC) Posts: 408  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
Originally Posted by: mct  Is there a way to easily replace the audio input with the zoom input, have that zoom input assigned as layer 1 on all these other inputs where the audio input was? The easiest way would just be to change layer 1 in all of those inputs. If you need to do it on the fly and/or otherwise don't want to do it manually, you can probably use a script that cycles through layer 1 on every input and changes it if it matches the audio input.
Double click the input you want to change and on general use the change butoon top right. Pick the source as if it would be a total new one and you are done. All layer assignments stay intakt.
