Morki
#1 Posted : Wednesday, October 30, 2024 2:32:20 AM(UTC)
Morki
Germany
I saved a vmix show as bundle to transfer it to another PC many times. But how can I "extract" all the data? I have a 2GB vmix bundle file that loads just fine, but I would be able to change images etc by just copying the new version to the correct folder like in my original setup...
I cannot find anything in the vMixStorage folder or anywhere else?! Is it always reading everything form the bundle file?
Morki
nikosman88
#2 Posted : Wednesday, October 30, 2024 3:11:06 AM(UTC)
nikosman88
Greece
Hello. See at windows\temp folder or when you going to open the bundle it says which folder will use. Also to be able to change anything,you can do it inside vmix by selecting the input you need to change and then change it by pressing the button change in the upper right corner. If you need to change it into folder based stage,it will take you more time,because the bundle is un-compressed in folders with strange numbers-name/per input so if you need to change for example the input x, you need to search in these folders. So better way remains change inside vmix and finally you can save again the new bundle for future use.
WaltG12
#3 Posted : Wednesday, October 30, 2024 5:34:17 AM(UTC)
WaltG12
Morki
#4 Posted : Friday, November 1, 2024 3:22:23 AM(UTC)
Morki
Germany
Thanks for the help.
Too bad all files get renamed, that way it is messy and hard to keep on working with such a file when you intend to exchange data from time to time :-(
AudioGreg
#5 Posted : Tuesday, November 5, 2024 1:05:12 AM(UTC)
AudioGreg
Was thanked: 23 time(s) in 20 post(s)
If you are needing frequent edits and using the preset on multiple machines, the better plan is to park your preset and resources on a shared network/cloud drive. Google Drive and OneDrive work very well for this.
