GT
GT Titles animation autostart on Mix 2 or others
we recently had a problem with GT titles that are played out on an additional created mix in VMIX.
We couldn't get them to play out with their in-animation if they were played out on any other mix than mix 1. Is there any trick to do this? We oftem have fullscreen animations for monitors inside of our sets that need to be played when the title goes live on mix 2.
Every box inside the "general" tab is checked (like "Automatically play with transition"). But it doesn't work.
Any idea?
Thanks and cheers
Robert
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
There is a function called "TitleBeginAnimation" to start the transitions or page animations manually.
Yeah - I saw that and tried it as trigger but it didn't work unfortunately.
I can't get the animation to play automatically, when I send the title to the mix (2).
Does it work on your machine?
Cheers
Robert
No, that's what I meant with "manually". :) You have to put it on a shortcut or better on a combined shortcut with the transition to mix 2. Triggers only work on mix 1.
 1 user thanked dmwkr for this useful post.
Great! Thanks for the quick reply.
I got it working now with two actions (cut & Begin Animation Page) on a single button in Companion. Thanks for pointing out that it needs to be set manually.
Cheers
Robert
GT
