Joined: 3/30/2023(UTC) Posts: 126  Location: Chicago Thanks: 11 times Was thanked: 6 time(s) in 5 post(s)
PLEASE, PLEASE, PLEASE!
Add more outputs. Even one or two would be great.
If it's an issue of varying system capabilities, maybe something that gauges whether it can be done using WMI and then if the processor can't just don't enable them.
OR alternatively, let zoom, vmixcall, etc, use a source directly rather than routing it through to the outputs first.
We really, really need it. We're doing multiple channels during programming whereby we'll want to stream out one thing, record something different, reflect back to zoom/vmixcall a third thing and then set up a delay to use a special Neilsen encoded audio stream. We're always bumping up against this limitation.
These are for the BIGGEST radio programs in the USA .... so our programming is seen by millions online.
This has also been an issue involving video and audio delay, that I've posted here separately (related to the Neilsen encoding noted above).
THANK YOU for considering this very seriously.
FYI, competitively, Viz Vectar/Tricaster has eight output channels.
Thanks,
Fritz Golman iHeartMedia
Hope you use mini mixes for your various targets
I am not.
I don't see what value in this situation I'd have from that.
Since I can only use output channels currently in assignment to stream, record, etc, why would I want to do that?
