Using Data Source to Change Input Layer Rotation
Joined: 9/7/2024(UTC) Posts: 63  Location: The Great PNW Was thanked: 10 time(s) in 9 post(s)
Hello everybody. I've gotten to the point where (I believe) I need to start dabbling into vMix scripting. I have an image input of an arrow. I need that arrow to change rotation based off of a value being delivered in a data source column. What is the most simple way to set an input layer's rotation to the value being reported in the data source, without manually triggering this action (ie: automatically updating without button press, preview, or overlay trigger, etc)...?
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: offroadmediagroup  Hello everybody. I've gotten to the point where (I believe) I need to start dabbling into vMix scripting. I have an image input of an arrow. I need that arrow to change rotation based off of a value being delivered in a data source column. What is the most simple way to set an input layer's rotation to the value being reported in the data source, without manually triggering this action (ie: automatically updating without button press, preview, or overlay trigger, etc)...? Kind of hard to do if there is no function available to rotate Also no possibility with a GT title Probably possible with XAML title with codebehind If not to many angles needed multiple images(of different angle) might be a way to go
Joined: 11/15/2021(UTC) Posts: 87  Thanks: 8 times Was thanked: 12 time(s) in 10 post(s)
a lot of work but a possible solution if you are familiar with after effects or similar software: 1. Make a 60 seconds video of the rotating arrow 2. set the angle using a script to Jump to the timestamp and Pause the video.
arrow up = Jump to 0 sec and Pause arrow down 30 sec, arrow right 15 sec…
If I'm correct, a script cannot access datasource entries directly. So you have to use a title input as a cache.
Per vMix support, "Currently, this is not possible. There are no shortcuts for adjusting the rotation of inputs or layers. We would recommend that you post a feature request (or find a similar request and add your support)." :( ...off to the feature requests...
