Linking a Streamdeck Shortcut to a Scoreboard update and a Title L3?
Joined: 10/13/2024(UTC) Posts: 2  Location: Scotland Thanks: 1 times
Hi. Apologies asking a question for my first post. Also wasn't sure where to post this. I have searched Google and the Knowledge Base and haven't been able to come to a solution, so...
Is it possible to use a Streamdeck and have Shortcuts set up e.g. +1 for a Goal being scored, which updates the Scoreboard, but also updates a Lower Third graphic for Half-time? So at half-time, say the User has pressed +1 three times to represent the score being 3-0, could this be updated on the L3 graphic without any manual typing?
Any advice much appreciated.
@ kiltedstreamer Yes, that is possible, simply clone your Shortcut to update two different Titles simultaneously. This article explains how to increase the score with a shortcut: https://www.vmix.com/kno...n-vmix-with-the-keyboardThis video explains more about cloning Shortcuts here: ?t=676 Ice
Joined: 7/4/2021(UTC) Posts: 408  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
If you have scripting available, you can also use a script at half time to pull the score from the scoreboard title and populate the lower third.
Originally Posted by: IceStream  @ kiltedstreamer Yes, that is possible, simply clone your Shortcut to update two different Titles simultaneously. This article explains how to increase the score with a shortcut: https://www.vmix.com/kno...n-vmix-with-the-keyboardThis video explains more about cloning Shortcuts here: ?t=676 Ice Oops, I didn't realise it would be as simple as this. I've cloned all the shortcuts and your solution works perfectly. Thanks for taking the time to reply, cheers!
