NBCU
#1 Posted : Wednesday, October 9, 2024 11:04:25 AM(UTC)
NBCU
on large productions when you use only specific inputs love to have the option to hide a number of inputs with a button to toggle show/hide. example i have 64 dante audio feeds that i don't need to see all the time on basic shows. Of for one show i don't need some assets. with a click of a button it can hide. I know you have tabs that you can separate to but then sometime you need to see more but not the ALL tabs. Another way to be able to do this is to be able to assign an input to multiple tabs
mavik
#2 Posted : Wednesday, October 9, 2024 9:14:29 PM(UTC)
mavik
Right clicking on the top section will minimize the input. This way you can have a high number of inputs but select the ones to focus on. Tabs are the second option to structure or group inputs.
NBCU
#3 Posted : Monday, October 14, 2024 9:42:21 AM(UTC)
NBCU
yes, i'm familiar with that but when you have two dozen dante audio feeds and a number of graphics for building like backgrounds etc it's a lot to minimize vs one togle button that does all at once or have a separate tab to put them in where they don't get seen in the all tab either.
