Our church has decided to combine vmix and easy worship onto a single computer. We have vmix streaming and set to display the output to a monitor in an overflow room as well. Our sound board is tied into our camera which connects to the pc via USB in order to get the preachers mic, etc. And we also use easy worship to play videos so the computer will have an audio output to the sound board for the audience in attendance. Since I need audio output in two places I believe I can set the audio to output to the sound board and use the easy worship NDI to pull in audio to vmix (does that sound correct)? But the problem we’re going to run into there, is the audio (USB) input from the camera is from the sound board it to will be output back to the sound board through the computer. So how the heck can I prevent this? Sorry I know I just confused everyone.
So it amounts to, I need easy worship output to vmix and speakers but camera feed only to vmix.
Joined: 7/4/2021(UTC) Posts: 430  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
If I understand your needs correctly, you have Audio from the soundboard that feeds to a vMix stream for anyone who's not in the room -This audio needs to only go to the vMix stream & not be returned to the soundboard Audio from video playback within the vMix computer -This audio needs to go to the soundboard, for the people in the room, as well as to the vMix stream for the people not in the room Do I have that correct? If so, this is what audio buses in vMix are for. You'll designate 1 bus for the stream and 1 bus for the soundboard return. Audio from the soundboard, you'll send only to the stream bus. Audio from the video playback, you'll send to both the stream bus and the soundboard return bus. For more info on setting up audio buses in vMix, they have a tutorial video:
