Hi! Here's a little feature request from us. We use vMix for visual radio, and sometimes use vMixCall when one or more hosts are out of the office, so that they can join the broadcast from wherever.
We wish to be able to control vMixCall with the api! It would be nice to be able to add the vMixCall input, and retrieve the URL using a GET-request. That way, our radio hosts can add guests to our automated vMix setup from the studio, whenever they need.
Thanks!
Regards, Sivert
Joined: 2/23/2023(UTC) Posts: 80  Thanks: 26 times Was thanked: 19 time(s) in 5 post(s)
The vMix XML API already exposes the password under the callPassword attribute: Code:<input
key="c89e4c82-52b4-421d-b9bd-cf457c7d417c"
number="2"
type="VideoCall"
title="Call1"
shortTitle="Call1"
state="Running"
position="0"
duration="0"
loop="False"
muted="True"
volume="100"
balance="0"
solo="False"
soloPFL="True"
audiobusses="M"
meterF1="0"
meterF2="0"
gainDb="0"
callPassword="0123456789"
callConnected="False"
callVideoSource="Output1"
callAudioSource="Master">Call1</input>
It would be nice to have the ability to reset an vMix call's password via an API call.
Originally Posted by: ryxyz  The vMix XML API already exposes the password under the callPassword attribute: Code:<input
number="2"
type="VideoCall"
title="Call1"
shortTitle="Call1"
state="Running"
position="0"
duration="0"
loop="False"
muted="True"
volume="100"
balance="0"
solo="False"
soloPFL="True"
audiobusses="M"
meterF1="0"
meterF2="0"
gainDb="0"
It would be nice to have the ability to reset an vMix call's password via an API call. Yes! This is what we want. To be able to add the input, retrieve the password AND set a new random password using the API.
