Feature Requests
Browser Input Integrations
Joined: 9/14/2024(UTC) Posts: 9  Location: Sydney Was thanked: 2 time(s) in 2 post(s)
Please consider adding DOM events triggered or functions called within the browser input to integrate better with vMix; a good starting point for these would be being able to trigger animations within Javascript on transition; so:
- TransitionIn
- TransitionOut
This would allow specifically built HTML pages to react to activities from vMix giving greater flexibility for building animations with JavaScript or webXR. The CasparCG HTML Producer does something like this with it's play, next, stop and update functions available within the browser DOM that are triggered from the software, allowing for very flexible and deeper intergration between the browser and production tools. Edit: Additional Information on other products implementing similar features:
 1 user thanked jared.quinn for this useful post.
Joined: 6/16/2020(UTC) Posts: 77  Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
I second that. I would also suggest integrating tally state as Javascript variables & events so that an upstream management system can know which HTML5 graphics are preview/live or not.
+1. This would solve a long-term problem for us.
Joined: 11/27/2017(UTC) Posts: 17   Location: Louisville, Kentucky Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
Awesome suggestion. Please integrate. +. 1
Originally Posted by: Palakis  I second that. I would also suggest integrating tally state as Javascript variables & events so that an upstream management system can know which HTML5 graphics are preview/live or not. Knowing the context of the transition event would be super useful in my workflows too! This could be as simple as providing a context to the transitionIn and Out triggers I've suggested that would contain details of the mix and if it was transitioned to/from preview or program for instance. Full tally probably should be done directly by the upstream management program rather than individual content sources which really only should get fed info about themselves for simplicity (and the option is always there for polling the API). On that polling note though - polling is less than ideal when you want a 250-500ms animation in that you want triggered immediately on take and even more time critical than polling could feasibly produce for a transition out.
Joined: 9/4/2023(UTC) Posts: 4  Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
This would be incredibly useful for us too.
Feature Requests
