Salleman
#1 Posted : Friday, September 13, 2024 11:17:01 PM(UTC)
Salleman
Sweden
When broadcasting sport we also display result from other matches and when showing the new score in the other games playing simultaneous from other arenas, it would be nice to show the teams who scored result flashing instead of just showing a sign with the new score
Today we get the data via APi and via DataChangeIn it automatically shows up in the right top corner for 5 sec
If under "animation" in GT Designer also was possible to chose flashing Transitions would be nice!
#2 Posted : Saturday, September 14, 2024 6:02:15 AM(UTC)
Was thanked: 1005 time(s) in 829 post(s)
Simple enough to do with a small script , when data is different (datachange) turn text on and off
Withtin GT title there is also the continuous blink option ( as you are only showing it when data changes for 5 seconds (better to do it on OnDatachangeOut)
Salleman
#3 Posted : Saturday, September 14, 2024 7:44:29 PM(UTC)
Salleman
Sweden
Yep, you're absolutely right there! However, I encounter a problem/challenge in how to handle the data flow for which I don't really have a good solution. The data coming from the APi is formatted (1 - 6) and on the next goal for the home team comes (2 - 6) so I will not in any good way just read the 1 to now the 2 without the whole (2 - 6) flashes. I just want the 2 to flash and how I can create code that determines which ab the numbers will flash. How do I get the code to determine, that in this case realize that it is precisely the 2 that is the difference. Tried with all the host's code-ish but unfortunately it fails. Any suggestions?
#4 Posted : Saturday, September 14, 2024 9:24:53 PM(UTC)
Using GT title split up the home - away score , will make your live easier be it using GT option or script option to make the value "blink"
If one can not change anything in the data source then put it in a hidden title text field first , retrieve it and split it up (script) before putting it in the actual text fields
Also its a good ideo to explain better your goal as it now is confusing aas to the show for 5 seconds , is that the blinking or the whole score ?
