Cropping Zoom inputs on layers of other inputs
Joined: 2/7/2024(UTC) Posts: 196  Thanks: 13 times Was thanked: 7 time(s) in 6 post(s)
I have been struggling with this problem for a while, if you select a Zoom input as a source for a layer of another input, you can't do any cropping on that layer. Positioning and even rotation works, but not cropping. But I just figured out that if you apply a key mask to the Zoom input itself, even if it's an all white mask that has no practical effect on the Zoom input, suddenly you can crop layers that use that Zoom input! Hopefully this saves some others the frustration I was dealing with
Joined: 1/13/2010(UTC) Posts: 5,352  Location: Gold Coast, Australia Was thanked: 4759 time(s) in 1633 post(s)
I just did a quick test with a new two input preset and the Zoom input can be cropped as a layer just like any other input. There must be something different being done in your particular preset, as I can't see any way that cropping would not be working.
Martin vMix
Yeah I don't know...if I make a new input and put a zoom input on a layer I can crop it fine, but with my inputs that I built and populated layers with inputs some Zoom and some not, I couldn't crop. If I figure anything out I'll let you know, thanks!
