Feature Requests
vMix Replay Features upgrade
Joined: 1/5/2013(UTC) Posts: 36   Location: Jamaica Thanks: 102 times Was thanked: 3 time(s) in 3 post(s)
As a professional replay operator, I would love to import video clips into the instant replay tab with fewer issues. Also, can we get the instant replay to link with another vMix replay machine and be able to “talk” over a network to share files if possible (similarly to EVS using XNet)? Is there a way when you do a live replay by scrolling back via a control surface that I can come back to live video by touching a button or mapping it on a surface to go back live on the output window? And can someone explain why while recording to an external drive for the replay, it was either playing back out at 50 per cent or it was playing choppy while doing a live replay or playing a playlist, I had to stop the replay tab.
When I was using it at a sporting event, I noticed that I had to use the stream deck to come back to live by using a jump to now button and then hit play via companion. Even when I wanted to play videos like the montage for highlights and features, I had to come out of the replay tab and play it from the regular video input. It would be nice to separate that and import the clips into the replay tab. I would like if I had 2 operators using vMix replay, it would be nice for them to talk to each other outside from NDI or play out angles from another input from the capture card.
If you want me to help in testing this feature out @vMix then let me know. The replay section in the software is very good but it can be done even better.
 1 user thanked Adriankey4 for this useful post.
+1 for being able to load clips.
Joined: 6/11/2020(UTC) Posts: 16  Location: San Francisco Was thanked: 5 time(s) in 4 post(s)
+1 for being able to upload clips into Instant Replay. We get this request a lot from different teams that have stingers for innings or topics like Home Runs, etc. Rather than having to play and record them in real time and them clip them off, if they could be imported it would save a lot of time and make switching between different teams much faster.
Joined: 5/20/2017(UTC) Posts: 63   Location: Philippines Thanks: 179 times Was thanked: 3 time(s) in 2 post(s)
+1 very usefull feature if implemented
+1 yes this would be great, import clips in REPLAY!! also it would be very nice if the SLOMO`s can get a Interpolation like on EVS... I know that's a other price range, but may be it is possible with the new possibility of GPU and CPU in the future... than vmix Replay is really a top solution for SLOMO Replay`s...
thanks Michael
Feature Requests
