ticker
#1 Posted : Friday, January 28, 2022 7:08:12 PM(UTC)
ticker
Hey all, trying to add a world clock to our ticker bar down the bottom, which flips between say 10 different city times every 10 seconds.
Any one been able to do this? I've done a fair bit of researching but really struggling. I've looked into APIs for world clocks etc but it just ends in a habit hole of google ads and nothing to show for it.
Cheers.
#2 Posted : Friday, January 28, 2022 7:41:36 PM(UTC)
Cheers.
using scripting will be your best bet to update the ticker content using a correct time format for the timing and zone selection (maybe even datasource)
Sure you want this in a ticker or is it an addition outside the ticker ?
see:
https://forums.vmix.com/...ng-for-Dummies#post89490
#3 Posted : Friday, January 28, 2022 9:11:32 PM(UTC)
Code:
'Title has Location.Text
'Title has timedif.Text to hold the timezone adjustment (will need to be hidden)
'Title has Zonetime.Text that will receive the current location time
' A data source  with Location in one column and timeadjust in the other
' link data source appropriatly (Location.Text  &  timedif.Text
' let the datasource auto loop with desired delay
' run the script
dim zone as integer = 0
dim oldlocation as string = ""
dim location as string = ""
dim zonetime as DateTime
do while true
   location = Input.Find("timezone.gtzip").Text("Location.Text")
 if location <> oldlocation
   zone = CInt(Input.Find("timezone.gtzip").Text("timedif.Text"))
   zonetime = DateTime.Now.AddHours(zone)
   Input.Find("timezone.gtzip").Text("Zonetime.Text")= zonetime.ToString("H:mm")
   oldlocation = location
 end if
sleep(250)
loop
leithgolding
#4 Posted : Thursday, February 10, 2022 10:30:13 AM(UTC)
leithgolding
thanks for this script, I used it on a show recently and it worked magnificatly, however one thing that I noticed is that we had a couple of timezones that are 1/2 hour differences for example Darwin is 1.5 hours behind Melbourne. when I pluged 1.5 into the spreadsheet it imported fine into the data manager as 1.5 but when the script ran it rounded the value up to 2! so Darwin was 2 hours behind rather then the 1.5 hours, is there something in the script that I missed?
thanks again for the help
#5 Posted : Thursday, February 10, 2022 6:36:59 PM(UTC)
Can't they do like most of the world ;-)
change:
Integer to Double
CInt to CDbl
Helpful info : Google-> What is Difference Between "int" and "double"
leithgolding on 2/14/2022(UTC)
leithgolding
#6 Posted : Monday, February 14, 2022 3:41:28 PM(UTC)
leithgolding
Thanks for the code!
we like to be a little different here!
MazajMusic
#7 Posted : Tuesday, August 27, 2024 7:57:01 AM(UTC)
MazajMusic
Lebanon
Originally Posted by: doggy Go to Quoted Post
Code:
' run the script
do while true
 end if
sleep(250)
loop
the script is stopping due to error line 19 conversion from string "" to type 'Integer' is not valid please assit me in correcting it to be able to use this wonderful script
#8 Posted : Tuesday, August 27, 2024 8:20:36 AM(UTC)
The script work totally fine (if there is a proper value in the title's timedif text field !, see comments at beginning of the script)
MazajMusic
#9 Posted : Tuesday, August 27, 2024 3:19:57 PM(UTC)
MazajMusic
Lebanon
thank you for your reply but I am not seeing what is the issue and why I am getting this error if it is working fine what did i do wrong? any suggestions?
#10 Posted : Tuesday, August 27, 2024 4:42:30 PM(UTC)
The "timedif" text field in the used title needs to have a value , can not be empty and must be a integer number
The error indicates that this text field in your title is empty or doesnt have a integer value within
With the script it gets populated by the datasource (as per structure example) , see vMix video tutorials on how to create titles and put data into them to display, using datasources and use them to populate titles etc
Question is are you using a properly structured title and datasource each filled with proper content?
Car will run just fine with the proper fuel in it
MazajMusic
#11 Posted : Wednesday, August 28, 2024 11:47:36 PM(UTC)
MazajMusic
Lebanon
thank you so much for your help it worked just fine but the only issue i am facing now that the script stops after few hours and I have to click start again is there anything i can do to make it run without stopping and the need to restart it?
#12 Posted : Thursday, August 29, 2024 2:17:39 AM(UTC)
Hard to know the casue if ther is no erro mentioned.
Maybe the frequency of checkig within the script might be a casue (to quick)
MazajMusic
#13 Posted : Thursday, August 29, 2024 4:47:54 AM(UTC)
MazajMusic
Lebanon
yes this is hard especially it is working just fine so i am wondering why it is stopped very few hours so i have to go to scripting section in vmix and click start i didn't change anything in the script i am using it as it
MazajMusic
#14 Posted : Friday, August 30, 2024 2:13:06 AM(UTC)
MazajMusic
Lebanon
hello again i found it when we reload the title the script stops and needs to be started again so i decided to tell it to you in case anyone face this issue same as me so whenever we reload the title we have to start again the script
#15 Posted : Friday, August 30, 2024 2:28:19 AM(UTC)
That's normal as during the reload the script goes iinto error as it cant reference that input at that moment anymore
What's the reason to reload the title in the first place ?
if you really have to have a shortcut ready to start this script then
MazajMusic
#16 Posted : Friday, August 30, 2024 4:11:09 AM(UTC)
MazajMusic
Lebanon
i am using it with a news ticker so when we update the news we need to reload
#17 Posted : Friday, August 30, 2024 4:34:55 AM(UTC)
No you dont, just change the text that needs to go into the ticker (manually, preset or datasource)
Please do a search on how to change title content (including tickers) . There are plenty of videos about that to be found, especially from vMix itself
MazajMusic
#18 Posted : Friday, August 30, 2024 5:49:39 AM(UTC)
MazajMusic
Lebanon
yes i do that but it doesn't update unless I reload i do not touch the ticker itself i update news in a csv file and save it but the ticker doesn't update the new news in the file unless it is reloaded so i guess i have to search about it to see why it is not updating from the csv without reload thx anyway
