I need to add a FLIR thermal camera to my inputs, but its an strange resolution of 640x514, and I am unable to select this in the add input camera. 640x480 is closest and it fail due to unsupported by camera. Any recommendations?
Joined: 12/24/2021(UTC) Posts: 705  Location: athens Thanks: 160 times Was thanked: 91 time(s) in 87 post(s)
Hello. Your capture card support this resolution?
It is a USB-C camera. It only gives out 640x514.
Maybe a workaround if vmix doesnt let you change the resolution is to route this camera from OBS (or other similar program) that support custom resolution in sources, by using output from this 3rd party program as ndi or virtual camera and then inside vmix.
Thank for the idea. I tried using NDI tools for that, but no luck. It works with normal webcam, but not the USB-c FLIR. Prefer not to run OBS only for this small task, but if I cant find any other way, I'll look into it.
