2 Pages<12
ocrtalk
#21 Posted : Monday, April 24, 2023 12:42:52 AM(UTC)
ocrtalk
I've been using MonaServer but am finding that it crashes a lot while live streaming.
I've installed Mist Server and have it working with RTMP but haven't tried it in a show yet to see how stable it is. I'm also struggle to get SRT to work with it. I know it's not necessary, but I'd like to have all of my connections in one place. Anyone done this and can lend some insight?
ocrtalk
#22 Posted : Wednesday, August 14, 2024 11:30:25 PM(UTC)
ocrtalk
I'm still on the search for a good rtmp server too. I think I've tried Mist and couldn't get it working. I've used NGINX and Mona Server some.
DJShaggyd
#23 Posted : Tuesday, August 20, 2024 9:46:17 PM(UTC)
DJShaggyd
South Africa
+1
ocrtalk
#24 Posted : Tuesday, August 20, 2024 9:58:26 PM(UTC)
ocrtalk
I'll add to this that SRT straight intovMix works great, but you can't use SRT in the live replay whereas RTMP you can. So another reason to need to use RTMP (or being able to use SRT in replay).
dmwkr
#25 Posted : Tuesday, August 20, 2024 11:21:17 PM(UTC)
dmwkr
From vMix 26 release notes:
"SRT inputs can now be used as Instant Replay sources. This requires turning off Use Hardware Decoder when adding the SRT input, as Instant Replay uses the CPU."
https://www.vmix.com/sof...aspx#vmix26-releasenotes
ocrtalk
#26 Posted : Wednesday, August 21, 2024 12:31:34 AM(UTC)
ocrtalk
Yes I'm aware of this, but setting 4-8 SRT feeds to use the CPU, I don't know. Maybe the AWS machine I use can handle it. I guess I should revisit testing.
Also, can regular videos not go into the instant replay? I show trail races but because cell signal makes live streaming very tough, we've been recording all of the cameras and then playing them back live. I'd love to be able to capture replays live. I turn around the show too fast to be able to go through and edit highlight clips.
thanks 1 user thanked ocrtalk for this useful post.
Adriankey4 on 9/2/2024(UTC)
Adriankey4
#27 Posted : Monday, September 2, 2024 4:06:41 PM(UTC)
Adriankey4
Jamaica
As a professional replay operator, I would love to import video clips into the instant replay tab with less issues, yes.
Also, can we get the instant replay to link with another vMix replay machine and be able to “talk” over a network to share files if possible (similarly to EVS using XNet).
Is there a way when you do a live replay by scrolling back via a control surface, I can come back to live video by touching a button or map it on a surface to go back live on the output window? And can someone explain why while recording to an external drive for the replay, it was either playing back out at 50 percent or it was playing choppy while doing a live replay or playing a playlist, I had to stop the replay tab?
When I was using it on a sporting event and I noticed that i had to use the stream deck to come back to live by using jump to now button and then hit play. Even when I wanted to play videos like the montage for highlights and features, I have to come out the replay tab and play it from the regular video input. It would nice to separate that and have the clips imported into the replay tab. I would like if I had 2 operators using vMix replay, it would be nice for them to talk to each other outside from NDI or playing out angles from another input from the capture card.
If you want me to help in testing this feature out @vMix then let me know. The replay section in the software is very good but it can be done even better.
Mano Bakker
#28 Posted : Thursday, September 19, 2024 6:38:29 PM(UTC)
Mano Bakker
Netherlands
+1
Guest (11)
Similar Topics
vMix as RTMP server & multiple streams (General Discussion)
by keglevich 11/13/2017 6:19:29 PM(UTC)
2 Pages<12
