Ham4u62
#1 Posted: : Saturday, August 10, 2024 11:33:17 PM(UTC)
Ham4u62
Iraq
Hi
I have a play list of items. I want to overlay an input every time that one of specific item plays in my list and if that one is not play turn the overlay off.
I'm not good at scripting but I used the blow code:
Code:
dim xml as string = API.XML()
dim GetInputNumber as string = ""
dim GetInputName as string = ""
x.loadxml(xml)
GetInputNumber = (x.SelectSingleNode("/vmix/active").InnerText)
GetInputName = (x.SelectSingleNode("//input[@number='"& GetInputNumber &"']/@title").Value)
do while true
if GetInputName = "List - B" then
sleep (500)
API.Function("OverlayInput1In", Input:="2")
else
API.Function("OverlayInput1out")
end if
sleep (500)
loop
My problem is this code works one time and not work every time But my playlist is in the loop.
#2 Posted : Sunday, August 11, 2024 12:22:36 AM(UTC)
Originally Posted by: Ham4u62 Go to Quoted Post
Hi
x.loadxml(xml)
do while true
sleep (500)
else
end if
sleep (500)
loop
GetInputName is never (able) to change within the loop ie the IF has always the same result !
Ham4u62 on 8/11/2024(UTC)
Ham4u62
#3 Posted : Sunday, August 11, 2024 2:29:05 AM(UTC)
Ham4u62
Iraq
Is there any solution to solve this problem?
#4 Posted : Sunday, August 11, 2024 2:38:59 AM(UTC)
Yes. It was given in the response.
your testing for a change but the change is not possible as the variable to check is not updated within the loop so it wil never change the the outcome within the loop
Correct the logic of the script
Ham4u62
#5 Posted : Sunday, August 11, 2024 2:53:18 AM(UTC)
Ham4u62
Iraq
I don't want change anything. I want to read active input name and turn on an overlay base on my condition.If condition not met turn an overlays off and do this through loop always.
can you give me a true logic based on my need
nikosman88
#6 Posted : Sunday, August 11, 2024 3:02:03 AM(UTC)
nikosman88
Greece
Hello. Try this one
Code:
dim xml as string = ""
do while true
    xml = API.XML()  ' Fetch the current XML each time inside the loop
    x.loadxml(xml)
    GetInputNumber = x.SelectSingleNode("/vmix/active").InnerText
    GetInputName = x.SelectSingleNode("//input[@number='"& GetInputNumber &"']/@title").Value
    else
        API.Function("OverlayInput1Out")
    end if
    sleep(500)  ' You can adjust this sleep if needed
loop
thanks 1 user thanked nikosman88 for this useful post.
#7 Posted : Sunday, August 11, 2024 4:19:27 AM(UTC)
Well you will have to , at least the logic of your script to get the desired intent !
Advice is to study how to programm , is only way to learn for future , instead of relying on a fixed answer especially a basic one like this (Google is a good friend)
I repeat , the solution was given , now Nikosman88 gave you the written solution , hope you will see that the provious answer were correct regarding the logic
Compare Yours and his and learn.
Ham4u62
#8 Posted : Sunday, August 11, 2024 4:58:11 AM(UTC)
Ham4u62
Iraq
Thank you doggy for your piece of advice. I'm learning scripting and specially logic first and said I'm not good at scripting.I searched and didn't find proper solution and decided to ask here.
nikosman88
#9 Posted : Sunday, August 11, 2024 5:33:03 AM(UTC)
nikosman88
Greece
I like to be honest. My answer to an allready 99% made script from Ham4u62 is AI generated answer and i dont feel any shame for it. At 2024 we also have a great tool to do things and personally im using it when i think it can help.
Ham4u62
#10 Posted : Sunday, August 11, 2024 5:35:25 AM(UTC)
Ham4u62
Iraq
Two Thumbs Up
It works Properly and fine
nikosman88
#11 Posted : Sunday, August 11, 2024 5:36:46 AM(UTC)
nikosman88
Greece
That`s the right way. First think how to do it and if you dont know,search. This is also how i work. For example if you didnt have the most script and go to chatgpt and ask from 0 to do it,it will fail.
