You have been a member since:: 9/27/2019(UTC) Posts: 49  Location: Kuressaare
Hi.
Does anyone know if there are alternatives to UTC? This is because it seems that it is no longer being developed, because the last update was on 03/26/2023, more than a year ago, and the program is outdated, constantly crashes on every move, or just closes itself at any moment. Is there something similar that performs the same function?
Joined: 11/27/2023(UTC) Posts: 123  Thanks: 9 times Was thanked: 8 time(s) in 8 post(s)
Try vMix Panel Builder....works great, constantly updated, and there are a few videos on line to assist you in getting started.....plus the developer will give you much needed help....I can help as well, as I use it a lot.....and have many layouts
Yes. Please I need help.
How can I make a button "Prev" and "Next" ?
Next Button - DataSourceNextRow (JSON) Prev Button - DataSourcePrevoiusRow (JSON)
How can I make Text Field to add text some Graphics input Title Layer ? - And I need that way same text must be many different Input Graphics Title Layer
How can I add NDI Input?
Is it some other project or paid software else? vMix Builder not support NDI source and Title layer change function. But I need these possibilities
