Joined: 8/12/2014(UTC) Posts: 1 Location: south africa
Hi All,
We are currently using a Data Video SD hardware mixer in our live environment, It takes 8 inputs of which 2 are DVI. it has 3 outputs Main, Aux1 and Aux2 would it be possible in vMix to have something like that (in terms of outputs)? The reason i'm asking is that we need to have multiple send buses so that we can display different things on the projectors and screens.
regards,
Joined: 12/29/2013(UTC) Posts: 54 Location: Mississauga, Canada
Thanks: 10 times Was thanked: 3 time(s) in 3 post(s)
See http://www.vmix.com.au/h...htm?SettingsOutputs.html for the Output options. In all versions of vMix, you can set a "Fullscreen" output (via secondary output of your video card) and an "External" output (via a separate output device). The screenshot below shows the settings screen for that:  In vMix 4K, you also get a second Fullscreen output and a second External output. These video mixing functionality of vMix will only affect the main Output and the Preview. If you choose Multiview or Input, I think you would have to go back into the settings dialog to change what those outputs display.
