Alex1234
#1 Posted : Wednesday, July 24, 2024 2:44:00 AM(UTC)
Alex1234
Germany
does anybody know if it is possible to change the Playback speed of a Video via a Button press on the Stream-Deck.
I know that i get the Play Back Speed when i right Click the Clip in Vmix, but is there no other Option?
Is it possible via Scripting?
I use Vmix as a source for a big LED-Screen as a Background on a Stage, and it would be nice to be able to speed up or slow down the video playing in the background according to the Music that is played. But to find the Clip, Right Click it and then set the speed is just to slow. A Command for + and - 10% would be perfect.
Thanks in Advance
Alex
dmwkr
#2 Posted : Wednesday, July 24, 2024 3:39:03 AM(UTC)
dmwkr
Was thanked: 160 time(s) in 144 post(s)
According to https://www.vmix.com/hel...tFunctionReference.html, the function is "SetRate".
Alex1234
#3 Posted : Wednesday, July 24, 2024 10:25:51 PM(UTC)
Alex1234
Germany
Thank you, it works like a charm.
