Feature Requests
Sorting Inputs by keying in a number
Currently it appears the only way to move inputs around is to do a drag and drop. It would be useful to be able to press and hold on the input number (for example) and then type in the number you want to move it too, and so it jumps to that location and pushes all the other inputs to the right - like a drag and drop.
Joined: 5/11/2020(UTC) Posts: 13  Location: Los Angeles Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
Hello Paul,
This is already in vMix.
Right click in the bottom right of the Input (the gear icon) and select "Move to" and then select the Input Number (that will move your selected input to that number).
For ex.: You are in the Input 30 and you want to move it to 4; right click in the gear icon in the Input 30 and select #4... Then the input #30 will be now in #4 and the previous #4 will be moved to #5... it's like drag and drop there without doing the drag and drop!
 1 user thanked profetauy for this useful post.
Thanks for letting me know.
Feature Requests
