Joined: 2/20/2019(UTC) Posts: 68  Location: Firenze Was thanked: 5 time(s) in 5 post(s)
Hello, looking at reference systems, as fot notebooks (Sapphire) Intel Core I7 13700H processor is suggested. Recently most gaming notebooks use HX version of the processor: are they still best choice for vMix, are they better or not suggested at all?
thanks for your suggestions
Joined: 10/20/2023(UTC) Posts: 166  Thanks: 3 times Was thanked: 18 time(s) in 14 post(s)
Originally Posted by: fabfab10  Hello, looking at reference systems, as fot notebooks (Sapphire) Intel Core I7 13700H processor is suggested. Recently most gaming notebooks use HX version of the processor: are they still best choice for vMix, are they better or not suggested at all?
thanks for your suggestions both are ok if you use pcie capture cards by thunderbolt, H-cpu version is best because thunderbolt directly managed by cpu for usb capture cards = HX-cpu
