drhurd
#1 Posted : Saturday, March 9, 2019 7:43:12 PM(UTC)
drhurd
Is there a way to Clear or Delete a single item from an Input list (EG.. One image)?
#2 Posted : Saturday, March 9, 2019 7:58:12 PM(UTC)
right click list input and choose edit items
drhurd
#3 Posted : Sunday, March 10, 2019 7:00:10 PM(UTC)
drhurd
I have right clicked everything and can not Clear an image from my Single Images Input List. It would be nice if there was a Clear Selected instead of Clear all images.
michaelrb
#4 Posted : Tuesday, March 12, 2019 6:29:09 AM(UTC)
michaelrb
What is the type of input did you set up. Is it "List"?
jmplunkett
#5 Posted : Friday, July 19, 2024 5:30:19 AM(UTC)
jmplunkett
Late reply - just joined.
Here's how I clean up inputs:
Open the preset list
Uncheck the items to be removed
Load the presets
Save them under the same name - sometimes I version number the preset files, just in case I need to restore the previous version
Input item is auto-magically removed.
This is done under version 27.
Luis70
#6 Posted : Friday, July 19, 2024 5:58:29 AM(UTC)
Luis70
Grenada
Was thanked: 11 time(s) in 11 post(s)
I delete my items fro the list in this manner....I click on the list button just under the Output (Program) window, and the list will open...I then click on the item in the list and it turns Orange...I then select 'Remove' and it is deleted...I also right click on the input window of the list, and select 'Edit Items', and the 'List window opens, so I just select the item I want to delete, and click 'Remove......
jcmax
#7 Posted : Saturday, November 22, 2025 1:52:46 PM(UTC)
jcmax
Kenya
Yes,, press the close button on the input
WaltG12
#8 Posted : Saturday, November 22, 2025 2:08:48 PM(UTC)
WaltG12
First of all, this is a 7 year old thread.
Second of all, it seems like nobody who replied actually read it.
Specifically, this part:
The wording is clunky, but the description should make it pretty obvious what's being discussed, which is the list of previously added image files on the "Add input" screen.
Third of all, this is an issue that was resolved some time ago. Again, it's a 7 year old thread describing a 7 year old issue.
In the past, clicking the "Clear" button--even after highlighting a specific file--wiped out the entire list.
That's no longer the case and hasn't been the case for a few releases now.
Clicking the "Clear" button now only clears the entire list if nothing is selected. Otherwise, it removes only the selections, as the OP sought to do.
So there's no need for further replies, considering they're all completely ignoring the clarification about the nature of the question, which is an issue that has since been resolved with an update.
