Zoom access not working anymore (Zoom Outage) (RESOLVED)
Joined: 12/10/2016(UTC) Posts: 126  Location: Frankfurt, Germany Thanks: 93 times Was thanked: 19 time(s) in 14 post(s)
Hi, I have latest vMix and Zoom plugin installed and cannot connect to Zoom on three different vMix systems. I cannot host or join a meeting anymore. Two hours ago it worked fine.
Does anyone experience the same? Is there an issue with vMix or the Zoom servers?
Joined: 7/9/2024(UTC) Posts: 1  Location: California Thanks: 1 times
Experiencing the same issue, zoom and vMix are both up to date, tried logging out and restarted vMix and my computer
Joined: 12/2/2014(UTC) Posts: 2 Location: Moscow, Russia
Thats a real problem, because we have a worldwide town hall meeting for a client and were in testing while suddenly everything stopped working…
Maybe it has to do with the issue described today in this thread https://forums.vmix.com/...uage-Interpretation-TipsZoom app (i have free-limit 40' minutes account) work ok. But Vmix cannot connect. So i assume some problem or new in-compatibility between zoom and vmix plugin
Joined: 1/13/2010(UTC) Posts: 5,374  Location: Gold Coast, Australia Was thanked: 4801 time(s) in 1648 post(s)
This appears to be an outage on Zoom's side, as they are currently blocking all 3rd party applications including vMix. Hopefully they will resolve this shortly.
Martin vMix
Well, this has ruined an event for me today. I had the preset ready and 1 hour before starting I noticed that it didn't work. And I have another one on Thursday. I hope you can solve it as soon as possible.
Originally Posted by: linkaman  I hope you can solve it as soon as possible.
It's not vMix's to solve but rather Zoom See second reply by admin
Joined: 11/27/2023(UTC) Posts: 137  Thanks: 10 times Was thanked: 11 time(s) in 11 post(s)
I have a suggestion....use the old fashion method....the screen capture method until the issue gets solved.....I have a friend on 27 with issues, and he used the screen capture method to avoid his client complaining....a method he is used to using....
Theres another program I have used in the past called VideoCom Bridge for Zoom. That also was not allowing me to connect to Zoo via NDI. It's not an issue with vMix and looks to be an issue on Zoom's side.
