Cant connect to teams live, i have set all the required settings. Tried other settings to whitout result.
Can sombody help me out what the problems is in this report:
King regards
Gilbert
FFMPEG1.Exited Metadata: encoder : Lavc57.106.101 h264_nvenc Side data: cpb: bitrate max/min/avg: 1500000/0/1500000 buffer size: 750000 vbv_delay: -1 Stream #0:1: Audio: aac (LC) ([10][0][0][0] / 0x000A), 48000 Hz, stereo, fltp, 160 kb/s Metadata: encoder : Lavc57.106.101 aac [tls @ 0966e0e0] Writing encrypted data to socket failed av_interleaved_write_frame(): I/O error Last message repeated 1 times [flv @ 09667520] Failed to update header with correct duration. [flv @ 09667520] Failed to update header with correct filesize. Error writing trailer of rtmps://emea.rtmpingest.mcr.teams.microsoft.com:1936/meeting/38851724949/fd2imm8: I/O error frame= 47 fps=0.0 q=11.0 Lsize= 211kB time=00:00:01.87 bitrate= 921.6kbits/s speed=9.63x video:208kB audio:1kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 1.199036% [tls @ 0966e0e0] Writing encrypted data to socket failed Last message repeated 1 times [tls @ 0966e0e0] Failed to send close message [aac @ 0966c3c0] Qavg: 65536.000 Conversion failed!
