bfish510
#1 Posted : Saturday, March 30, 2024 10:05:21 AM(UTC)
bfish510
Vmix has run via Parallels prior to 27.0.0.72 on Apple Silicon Macs without major issue, outside of Instant Replay. While Vmix does not provide support for this use case, this update in an incremental build changes that to actively prohibited.
In addition this change is not called out in the changelog.
Please consider rolling this change back to prevent customer impact for those productions that had a working setup prior to 27.0.0.72 and had to reinstall due to unforeseeable reasons. If this change is required, please consider doing so under at least a 27.1 semver to call out the significance with reference to where impacted customers can find prior versions.
#2 Posted : Saturday, March 30, 2024 12:26:58 PM(UTC)
Was thanked: 4735 time(s) in 1624 post(s)
We have made no such change or restriction in 27.0.0.72.
You may need to contact support and provide more information on the error:
https://www.vmix.com/contact-us.aspx
bfish510
#3 Posted : Saturday, March 30, 2024 3:08:30 PM(UTC)
bfish510
Build 72: First screen running install exe
Build 69: First screen running install exe
System is a MacBook Pro with an M2 Max, 32 GB of Ram
Vmix is running on Windows 11 run via Parallels
ayo
#4 Posted : Monday, July 1, 2024 8:17:07 PM(UTC)
ayo
were you able to solve this?
