TL68
#1 Posted : Thursday, February 15, 2024 5:49:09 PM(UTC)
TL68
Sweden
Hi!
I really miss an undo (Ctrl+Z) command to recover an accidentally removed replay event from the list.
Cheers!
T
monamiga
#2 Posted : Tuesday, June 25, 2024 8:45:41 PM(UTC)
monamiga
Philippines
+1
#3 Posted : Tuesday, June 25, 2024 10:07:37 PM(UTC)
Originally Posted by: TL68 Go to Quoted Post
Hi!
Cheers!
T
Unless one is using a shortcut (only works on a single event) to remove an event it is a 3 step action to remove one ( right click on selected event, choose "remove" and confirm).
An event is just markers ( in/out) as the footage itself is not gone.
As long as one hasnt changed stopped/started status of the IR recording or added an event there is still a reference to the "removed" event(s) with their in/outpoints in the replay2.xml in the recording folder.
An undo could be handy IF one realised it Before any other IR Event action is done.
If one encounters this "accident" frequently using shortcuts a sugestion might be to use the MoveEvent to another eventlist instead as a shortcut and delete those later. JMO
Guest (4)
