Streampunk
#1 Posted : Saturday, June 22, 2024 3:48:39 AM(UTC)
Streampunk
Israel
Hi, bus B audio stopped working for me going into a live event after it was fine in testing the day before.
I tried restarting vmix and rebooting the computer several time to no avail,
I switched bus B output from "enabled" to other outputs but nothing changed
I enabled bus C, and the audio didn't work either.
Meanwhile bus A output audio was running fine
The next day, I had a new live event and bus B worked normally, I opened the previous project and it worked too.
This happened to me only once before, and restarting vmix solved it
So what do you think happened now?
I'm not sure what to make of it
Here's a snapshot I took at the time
Follo
#2 Posted : Monday, June 24, 2024 8:20:43 PM(UTC)
Follo
Germany
Was thanked: 17 time(s) in 10 post(s)
maybe Bus B Volume slider is turned down in the Bus Mixer of your Input.
To check, go into the Audio settings of your audio input, click Bus Mixer and turn up the slider for Bus B.
Or its the Cahnnel Matrix odf your audio Input.
To check, go into the Audio settings of your audio input, click Channel Matrix and turn on Bus B (L and R).
Hope that helps.
Best reagrds
