Joined: 3/30/2023(UTC) Posts: 126  Location: Chicago Thanks: 11 times Was thanked: 6 time(s) in 5 post(s)
I'm sure this has been requested many times but I can't emphasize enough the need for additional output channels now.
In light of all sorts of new capabilities that have recently been rolled out in v27, the four channel output limit is really a brick wall.
Please, please add a couple more! Even if this becomes a tradeoff with other capabilities, I'd generally be fine with that.
I'd suggest that a more modular approach might be a solution whereby you'd be able to load only the components needed rather than a much larger impact of everything available at all times even if not used.
Thanks for the consideration.
Fritz Golman IHeartMedia Chicago
I can't believe that this hasn't been up voted!
Originally Posted by: fgolman  I can't believe that this Haggerty) hasn't been up voted! +1 but the real thing is that this has been discussed so many times. I believe that it will come,when vmix team think that is ready to come. Soon or later
