Joined: 1/4/2024(UTC) Posts: 2  Location: United States Thanks: 1 times
Hi everyone, I'd like to be able to change the speed at which an image sequence plays back. Ideally if I have a sequence of 2000+ frames that were built at 60fps I'd like to be able to play it essentially at a 20fps rate or 33% of the speed without needing to bring the sequence into premiere or after effects and rendering triple the amount of frames to accomplish this. Let me know if you have any thoughts about how to accomplish this in any other way. Thanks in advance!
Originally Posted by: onemillionpushups  Hi everyone, I'd like to be able to change the speed at which an image sequence plays back. Ideally if I have a sequence of 2000+ frames that were built at 60fps I'd like to be able to play it essentially at a 20fps rate or 33% of the speed without needing to bring the sequence into premiere or after effects and rendering triple the amount of frames to accomplish this. Let me know if you have any thoughts about how to accomplish this in any other way. Thanks in advance! Change the playback speed of the input
