Feature Requests
Replay Cam (on/off) selected to activators
Joined: 6/15/2021(UTC) Posts: 13   Location: Bydgoszcz Was thanked: 4 time(s) in 3 post(s)
The need concerns adding to the activators the selection of replays from the replay system when using, for example, StreamDeck
In the case of replays from several cameras, it would be useful to have the option to configure the streamdeck - from which camera the replay is selected (e.g. green button) and from which not (red button)
In detail - if the replay is marked with a white square, i.e. it is selected, it is enabled - the streamdek key will highlight in one selected color, and when it is not selected, it is disabled, the streamdek key will highlight in the second selected color.
I hope I managed to describe exactly what I mean.
Joined: 12/27/2012(UTC) Posts: 5,527  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: FKmedia  The need concerns adding to the activators the selection of replays from the replay system when using, for example, StreamDeck
I hope I managed to describe exactly what I mean. How would that work when multiple events were to be selected for replay?
I see it just like under:  Replay activator.png (72kb) downloaded 7 time(s).
 2 users thanked FKmedia for this useful post.
Originally Posted by: FKmedia  I see it just like under:  Replay activator.png (72kb) downloaded 7 time(s). With multiple events selected ?  multipleevent.jpg (75kb) downloaded 4 time(s).
During live broadcasts, you do not need (i do not need) to repeat all events, I repeat only the last one.
You repeat all events at most at the end of the broadcast or during a break. So if you mark each new one what you want to show and what not, you are ready to repeat all of them at the end.
 1 user thanked FKmedia for this useful post.
Originally Posted by: FKmedia  During live broadcasts, you do not need (i do not need) to repeat all events, I repeat only the last one.
You repeat all events at most at the end of the broadcast or during a break. So if you mark each new one what you want to show and what not, you are ready to repeat all of them at the end. Ok then , restricted to last event only then (for you) ?
Last and selected (to choose / optional)
Joined: 7/16/2021(UTC) Posts: 3  Location: Orem, UT Was thanked: 1 time(s) in 1 post(s)
I'd really like to see this too. I use an X-Keys controller, and it would be really nice to have the buttons I have setup to indicate whether a particular camera is active for the currently selected event. I can toggle them, but I can't have the lights on those buttons lit up when that camera is selected.
In the case where multiple clips are selected, the lights should follow whatever logic is used for the toggle logic... so if the light is lit up and the button is pressed, that camera is turned off for all selected clips, or if the light is not lit, pressing the button turns it on.
Likewise, an activator for the Live status would be tremendously helpful!!!
 1 user thanked gotgadgets for this useful post.
Joined: 10/21/2022(UTC) Posts: 24   Location: ankara Thanks: 16 times Was thanked: 4 time(s) in 3 post(s)
Originally Posted by: FKmedia  I see it just like under:  Replay activator.png (72kb) downloaded 7 time(s). Where can we do this by selecting it in Activator? I couldn't find it.
Feature Requests
