ALCVMixAxes
#1 Posted : Sunday, June 16, 2024 7:36:16 AM(UTC)
ALCVMixAxes
Canada
Hello everyone,
I am creating a JSON Data Source, confirmed that there is data on the web page, however no data is being pulled through the Data Source Manager.
I can use other types of Data Sources (RSS, text, etc) and there are no issues pulling data in, it's only with the JSON.
Can anyone lead me in a direction to try and correct the issue? I'm a first time user of VMix so I don't know my way around well enough yet.
Thank you.
#2 Posted : Sunday, June 16, 2024 8:04:35 AM(UTC)
Originally Posted by: ALCVMixAxes Go to Quoted Post
Hello everyone,
Thank you.
Check the helpfiles https://www.vmix.com/help27/DataSourcesTypes.html
JSON
This supports JSON data that is stored as an object array.
Each element in the array will be treated as a row.
ALCVMixAxes
#3 Posted : Sunday, June 16, 2024 8:08:39 AM(UTC)
ALCVMixAxes
Canada
Unfortunately that's no help.
I have no issue connecting to this source on my laptop copy of VMix, it's just on my production computer that I can't get the data to pull through. I don't know if there is a setting somewhere in the software that's blocking it?
ALCVMixAxes
#4 Posted : Sunday, June 16, 2024 8:11:54 AM(UTC)
ALCVMixAxes
Canada
To be clear, the production computer is connected to the internet, I can pull other internet based data sources (RSS feed), the API address for the JSON has data I can see in a web browser, it just won't pull through when I set up the Data Source via the Manager
#5 Posted : Sunday, June 16, 2024 8:18:30 AM(UTC)
Again: JSON data that is stored as an object array.
it wont pull properly if it doesnt contain a object array
Maybe post an example of the json file else one is only guessing
ALCVMixAxes
#6 Posted : Sunday, June 16, 2024 8:22:03 AM(UTC)
ALCVMixAxes
Canada
This is the site I'm using:
https://api.axescores.co...24-WilsonCup/orange/left
The website returns this string:
{"players":{"left":{"name":"Austin Agosti","roundsWon":3,"roundScore":25.0,"throws":{"1":{"label":"1","value":"5","clutch":false},"2":{"label":"2","value":"5","clutch":false},"3":{"label":"3","value":"5","clutch":false},"4":{"label":"4","value":"5","clutch":false},"5":{"label":"5","value":"5","clutch":false}},"bigAxes":null},"right":{"name":"Adrian Gagnon","roundsWon":0,"roundScore":18.0,"throws":{"1":{"label":"1","value":"5","clutch":false},"2":{"label":"2","value":"5","clutch":false},"3":{"label":"3","value":"3","clutch":false},"4":{"label":"4","value":"5","clutch":false},"5":{"label":"5","value":"0","clutch":true}},"bigAxes":null}}}
ALCVMixAxes
#7 Posted : Sunday, June 16, 2024 8:50:53 AM(UTC)
ALCVMixAxes
Canada
this is the web address I'm pulling from:
The data string in the web browser is:
#8 Posted : Sunday, June 16, 2024 9:31:20 AM(UTC)
Exactly as mentioned before, there is no array
Json Arrays are enclosed with [ ]
see google search for "json array"
if you are ok with the fact all this data is in one row try the folowing script
Code:
Dim thesource As String = New System.Net.WebClient().DownloadString("https://api.axescores.com/stream/2024-WilsonCup/orange/left")
thesource = "[" & thesource & "]"
System.IO.File.WriteAllText("D:/Test.json", text)
and load the Test.json file as your json datasource
ALCVMixAxes on 6/16/2024(UTC)
ALCVMixAxes
#9 Posted : Sunday, June 16, 2024 9:41:24 AM(UTC)
ALCVMixAxes
Canada
Thank you for this, I'll give it a try.
There must have been that small difference when I was testing with an older link and didn't have the problem.
