Hey Y'all, wondering if it's possible to ease in and out of transitions. Most of the transitions are jarring with sudden starts and stops, unlike GT Title animations where I can control the timing style.
Joined: 9/12/2021(UTC) Posts: 23   Location: Medicine Hat, AB Thanks: 1 times
Originally Posted by: tilambtw  Hey Y'all, wondering if it's possible to ease in and out of transitions. Most of the transitions are jarring with sudden starts and stops, unlike GT Title animations where I can control the timing style. Yes. So I've recently had this question as well. I've found then when using the "MERGE" transition, there seems to be an adequate (though seemingly unconfigurable) transition easing on that by default. However, if using transitions within an Overlay or transitioning between elements natively (not via GT Title Designer) the transitions are VERY linear and unappealing. It would be nice if there was a transition easing default (which could be overridden by the GT Title Designer settings if applicable), though I'm sure normally GT Titles are transitioned to via a CUT rather than a transition animation... not to mention the fact that many VMix users don't have GT Title Designer in the first place. Either way, adding an easing option would sure increase the product output considerably. So... this is definitely a +1 from me!
Thanks: 9 times Was thanked: 2 time(s) in 2 post(s)
I ***ABSOLUTELY*** agree with this, and asked the same question some time ago.
It would be pretty easy (programatically) to set some mathematical easing methods to the transitions.
It's amazing, really, how MUCH an easing affect improves the professional look of your production.
The fact that this was proposed by you 2 years ago, and it still hasn't been implemented is a bit disheartening.
Adding my support for easing merge transitions by adding timing settings.
Joined: 12/8/2022(UTC) Posts: 167  Thanks: 51 times Was thanked: 3 time(s) in 3 post(s)
Joined: 2/23/2023(UTC) Posts: 81  Thanks: 26 times Was thanked: 20 time(s) in 6 post(s)
Thanks: 14 times Was thanked: 1 time(s) in 1 post(s)
+1 from me as well. Would love to have this added!
Joined: 11/27/2023(UTC) Posts: 133  Thanks: 10 times Was thanked: 9 time(s) in 9 post(s)
Streaming Alchemy has something that I think may be what you all are talking about.... it is a script that does a fantastic job with the merge effect here are 2 examples I downloaded and use ... maybe anyone who knows how to write scripts can make their adjustments:  SMART MERGE A.txt (8kb) downloaded 9 time(s).
