Dave Cruickshank
#1 Posted : Friday, June 14, 2024 9:45:49 AM(UTC)
Dave Cruickshank
Canada
When I add "Title Editor" text into a title (And click the PLUS icon to save them)... it would be nice to be able to drag those up or down (or even just select and click an up or down icon) in case I add one after the fact. I like to keep my titles in the order in which I'm going to use them for ease of use.
mavik
#2 Posted : Friday, June 14, 2024 9:10:06 PM(UTC)
mavik
The best option I would like to suggest is to use a csv file for your titles and use it as a datasource. This way you can even ask the client to create it for you to avoid typos.
#3 Posted : Friday, June 14, 2024 9:51:25 PM(UTC)
Fully agree on the datasource path (not to mention easier way of selecting the wanted data from an stay open datasource manager etc).
Not so much on the second part LOL. Can't count the number of times we had to correct such lists for typos, all Caps for some rows, to saved wrongly and losing all special language characters ;-)
Dave Cruickshank
#4 Posted : Tuesday, September 8, 2026 5:21:44 AM(UTC)
Dave Cruickshank
Canada
I agree, you can create a CSV and use it as a datasource (which is exactly what the title editor is doing anyway...). I can EXPORT that data, reorder it, and re-import it back into the title. Fine. I know that works. (My client (a funeral chapel) adds titles directly into the title editor based on the funeral they are presenting that day, rather than having to deal with csv files or external datasources.)
For simple titles, accessing external data sources seems to be adding unnecessary complexity to (what should be) a simple matter of just re-ordering the titles. There SHOULD be a method to simply move a title up or down within the title editor in Vmix. This is simply a QOL request.
