I have a Logitech Brio camera. The frame rate in vMix is only 5fps using the Logitech Brio driver in vMix. However, if I use the Logitech Brio MF driver, the framerate is correct, except this driver does not include audio. Any ideas? Thanks!
Joined: 2/7/2024(UTC) Posts: 195  Thanks: 13 times Was thanked: 7 time(s) in 6 post(s)
Originally Posted by: mkrigsman  I have a Logitech Brio camera. The frame rate in vMix is only 5fps using the Logitech Brio driver in vMix. However, if I use the Logitech Brio MF driver, the framerate is correct, except this driver does not include audio. Any ideas? Thanks! Not sure why you'd have a framerate issue, but I have used BRIOs and other Logitech cameras and have been disappointed almost every time. I've had BRIOs just randomly blink to black and other issues. You might consider just getting another brand if nothing else to test with.
