john30120
#1 Posted : Wednesday, June 5, 2024 6:53:26 AM(UTC)
john30120
I have a script that loops until the designated starting time then proceeds on to start a stream. Presently the starting time is hard coded as a string.
I would like to be able to enter the desired starting time as the script starts. How do you call up an inputbox at runtime?
nikosman88
#2 Posted : Wednesday, June 5, 2024 8:32:54 AM(UTC)
nikosman88
Greece
Hello. I dont know much for scripts. But im running this script https://github.com/rse/v.../master/recording-log.vb that when we set a dynamic value to "recording-marker-custom" it opens a dialog and you can write anything. I dont know if you can take this part of code and combine it for your needs. Also there is a thread for scripting https://forums.vmix.com/...ng-for-Dummies#post70735 maybe for take ideas.
#3 Posted : Wednesday, June 5, 2024 10:13:25 AM(UTC)
have a "unused" title and enter the startime string in a textblock, let the script read it
john30120
#4 Posted : Thursday, June 6, 2024 8:36:18 AM(UTC)
john30120
I have used titles to store variables and share that data between scripts. But it may not be possible to do what I'd like. What I want to do is start a script and have it ask the user the desired Start time. I know the script can enter data into the title but can the user input data into the script after it has been started?
#5 Posted : Thursday, June 6, 2024 1:56:50 PM(UTC)
No
Not in the script directly
nikosman88
#6 Posted : Thursday, June 6, 2024 8:18:30 PM(UTC)
nikosman88
Greece
So if this is not possible to do you can do a workaround with using bitfocus companion triggers or a 3rd party scheduler program for vmix that will do the action for streaming or start a script directly or via some other input
