Feature Requests
Twitch Enhanced Broadcasting Support
Twitch is currently testing Enhanced Broadcasting, which is how they will enable HEVC and AV1 streams later and currently improves quality by not relying on their transcoding.
Currently, I'm enabling enhanced broadcasting by sending NDI from vMix to OBS, but this setup runs at 90% CPU usage and bumps up right against the NVENC session limit (and has a noticeable generation quality loss from the NDI compression).
Having native support for this in vMix would be a huge upgrade. If I'm not mistaken, vMix already supports RTMP+ for sending HEVC and AV1 to YouTube, so hopefully y'all can work with Twitch to enable this.
Originally Posted by: nuudlman  Twitch is currently testing Enhanced Broadcasting, which is how they will enable HEVC and AV1 streams later and currently improves quality by not relying on their transcoding.
Having native support for this in vMix would be a huge upgrade. If I'm not mistaken, vMix already supports RTMP+ for sending HEVC and AV1 to YouTube, so hopefully y'all can work with Twitch to enable this. I'm waiting for Twitch Enhanced support as well. I'm usualy stream on Twitch... Greetings from Switzerland Manuel
Joined: 12/19/2019(UTC) Posts: 67  Was thanked: 28 time(s) in 20 post(s)
Duplicate of my earlier Feature Request https://forums.vmix.com/posts/t31930-Multitrack-Video-support. To support Twitch Enhanced Broadcasting it's specifically the underlying technology for Multitrack Video that needs to be implemented in vMix for their to be support for Twitch Enhanced Broadcasting, and the growing number of other services such as AWS IVS that also support being sent multitrack video.
Feature Requests
