Ferdeso
#1 Posted : Monday, June 3, 2024 4:55:47 AM(UTC)
Ferdeso
Spain
I have purchased the hollyland tally system but I am somewhat lost in getting it up and running with vmix, does anyone know how to do it?
https://www.hollyland.co...ct/wireless-tally-system
Lennart
#2 Posted : Monday, June 3, 2024 7:22:34 AM(UTC)
Lennart
Denmark
Was thanked: 17 time(s) in 16 post(s)
Have you checked out the manual?
https://www.hollyland.com/download/wireless-tally-system
It seems like you need to get it on the network and then point it to your vMix.
Ferdeso
#3 Posted : Monday, June 3, 2024 7:54:43 AM(UTC)
Ferdeso
Spain
Yes, what I have done so far has been to configure a local IP within my range for the tally itself and then in the IP switcher I have assigned the local IP of the PC that contains vmix, at the moment I have not done it that way work, my question is if something needs to be configured in vMix.
Ferdeso
#4 Posted : Monday, June 3, 2024 8:21:12 AM(UTC)
Ferdeso
Spain
I have already managed to get it to work, it was some problem with the network I was on, I have tried it on another different physical network and it works well assigning the IP to the tally and the IP to the PC with vmix and it works automatically, now I have to see why in The network it was on is not working, in case it affects some type of firewall.
Thank you!!!!
ONV
#5 Posted : Tuesday, September 17, 2024 1:26:52 AM(UTC)
ONV
Germany
Thank you!!!!
Hey Ferdeso,
just a quick follow-up: Did you have any success in your investigation what went wrong? I seem to have similar issues. Bought a new set of Hollyland Tallys and we could-not-get-them-working with vMix.
As I understand it you only have to enter the vMix IP (the web controller/tally IP) into the Hollyland base station, right? That's what we did. We also tried to connect the PC to the base directly or via two different routers. No luck. When we plugged in an ATEM and entered it's IP into the base station everything worked!
To this day I have no idea what the issue is...
Thanks!
Olly
