vmix wireless setup and VT-PZ8121W
Has anyone user VT-PZ8121W with vmix? we are looking in purchasing 2 of this cameras and feed them to Vmix for live streaming. Anyone with Experience regarding VT-PZ8121W please share it here Also Vmix Admin maybe can tell if the VT-PZ8121W is supported by vmix software
If anyone had success setting up a wireless camera that it does zoom pan and tilt you are welcome to share it here for others.
Thank you
no One has experience with wireless pan tilt cameras ? also Admin you goys have not tested vMix with any of the IP cameras from vivotek or geovision? this are big brands in surveillance and cameras..
Thanks: 1 times Was thanked: 7 time(s) in 7 post(s)
According to THIS datasheet, it appears the camera supports 2 RTSP streams See page 46 of document. To access RTSP streams, set authentication to 'disable' use the one of the following connection strings, where x.x.x.x is the IP address of the camera rtsp://x.x.x.x/live.sdp rtsp://x.x.x.x/live2.sdp To add the IP camera as an input, select 'stream' from the input list and enter the connection string shown above. If the stream does not work, enable 'low latency mode' and try again  NOTE: you will not be able to control PTZ from vMix - that must be done by another method
